Panasonic tc-p55gt30
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    #141
    Re: Panasonic tc-p55gt30
    Here is a picture of the back.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      #142
      All the boards and parts are exactly the same excep the vt30 seems to have a subwoofer in the back, the black speaker in the middle, that runs to a connection on the mainboard.
      The two main boards have two different model numbers but I suspect the difference may be he subwoofer connection?
      Tomorrow I may try the mainboard from the working gt30 in the vt30. According to the service manual, it looks like the mainboard is the problem.
      Tired of messing with it tonight.
      I had purchased an sc board because I only had 1 between the 2 TV but when it arrived today it was for a tc-p50st30.
      Completely different. So I'll have to exchange it.
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        #143
        Funny how the led stays red. My exact same tv shows a green led when its on.
        Can you get the tv to display a picture? Like the menu? If the connections are the same you can also try the mainboard from the GT. Most of the times its almost the same but misses a extra hdmi/usb etc. If all connections are the same it will 90% work.
        • Moreno83
          • Jun 2014
          • 2008
          • The Netherlands
          #144
          It's a learning process but its fun. Don't forget you traded a "cheap" lcd for a good looking expensive GT30!!! If you sell it you will double/triple your money.
          I would not sell it unless you can get a VT50 or VT60. Panasonic stopped making plasma's after the VT60 so its a wanted tv that you have.....
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            #145
            I'd prefer to get them both working and keep both and sell my 2 lg plasma tv's.
            If I have to sell one of the panasonics, I'd rather keep the vt30.
            I got the gt30 for the free 37" I fixed but it had no sc board. The sc board canoe out of the vt30 that I paid $150 for plus it was shorted, so $80 to fix it. So far it's cost me $260 to get 1 gt30 working. Not so cheap.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              #146
              I couldn't wait till tomorrow. I would not have been able to sleep. The main board from the gt30 in the vt30, no difference.
              So it must be something else.
              I just checked the sd board again and now there is a short. Shouldn't part of the screen have a picture then? Or would it affect the whole thing?
              • tw2005
                • Oct 2011
                • 6458
                I was going to suggest bad buffers , it appears the upper portion has some panel activity and lower half is black.
                Somewhat surprising no error blink.
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  #148
                  Did you also transfer the bufferboards from the GT to the VT? Looks like bad buffer board on the VT. Can you get any picture at all or just the black bars only?
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    #149
                    No picture at all. Just as the picture shows.
                    After he struggle i had reseating the ribbon cables, I didn't want to take them off the working TV to try it on the other.
                    I'll just buy one.
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      #150
                      Ok , that might fix the tv. You can fix the SC board yourself if you can solder
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        #151
                        There is no sc board. The one I have works.
                        The SD board is faulty but I'm not skilled enough to repair it. So I'll have to send it out for repair or buy a used working one.
                        Would mine repaired be better than a used one that may not be repaired?
                        A repaired one may last longer because of better components used in the repar?
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          #152
                          So I took the mainboard out of the non working p55vt30 and put it in the working p55gt30.
                          3/4 of the left screen worked. I could access the menus, ods and make changes.
                          The right 1/4 of the screen didn't work.
                          I checked the sd board again as tw2005 instructed and no beeps with meter in diode mode.
                          So I don't know if I have a bad A board and/or SD board.
                          I'm getting tired of messing with it.
                          A used A board is $120 plus shipping, $80 for an SD board, I have to find an SC board and I paid $150 for the TV.
                          Starting to not seem worth it. Maybe I should give up on the 55vt30.
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            #153
                            Hmm , it can be that the VT30 mainboard does not work in the GT30 , don't know how that works with firmware/service menu settings etc. It can be a defective mainboard , im not sure.
                            So if you put the GT30 mainboard back in , the picture is fine. Right?
                            You could try and use the bufferboards from the VT50 into the GT30 to see if it works. If so , then you can rule them out. It takes a bit of work but its worth the try!
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              #154
                              Put the gt30 main board back in, all is fine. I think I'm going to order a main board.
                              Following the chart in the service manual indicates the main board is bad.
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                #155
                                I think I'm giving up on this tc-p55vt30.
                                I got a new A board and today I new SD board but it didn't seem to solve the problem.
                                The bottom of the screen which previously was all black now has bands of lighter black but still not working.
                                So I guess I'll return the A board and SD board and be done with it.
                                I might keep the SD board to use if the one in the p55gt30 goes bad.
                                In a few years it might be harder to find.
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  #156
                                  I have taken every board out of the p55vt30 except for the 2 power supply boards and the bottom C boards and put them in the p55gt30 and they all work.
                                  Even the A board and the subwoofer.
                                  I don't know if that means that the TV is now a p55vt30 or if the panel itself is somehow better on the p55vt30.
                                  The panel numbers are lightly different.
                                  The p55gt30 is MC140FJ1431 and the p55vt30 is MC140FJ1443.
                                  The bezel in the front is different.
                                  The p55gt30 has a plastic bezel and the p55vt30 doesn't.
                                  I'm thinking since the boards work in the gt30 that somehow the vt30 panel is bad.
                                  Now I have to decide if I want to keep all the internal parts for spares to the p55gt30 or sell them.
                                  What would the recommendation of the forum members be?
                                  • iddomilan
                                    • Feb 2016
                                    • 6
                                    Hey All, my first post.
                                    I recently aquired a TC-P55GT40 with the 7 blink problem. After a bunch of online research, I learned a bunch of parts fail on the SC board causing 7 blinks so I purchased the repair kit from shopjimmy to fix it. After replacing all of the parts with the new kitted parts, I no longer get 7 blinks :-) but the bad news is I get 6 blinks instead :-( If I removed the SC20 ribbon cable, I get 8 blinks, which accoding to my research means a problem still exist on the SC board. I have looked for shorts, but I am not finding anything. Any sugguestions besides buy a new SC board? I am not finding a ton of infomation on the 6 blink problem as I did on the 7 blink problem. I have been trying to reverse engineer the energy recovery circuit which I am hoping will help me find the issue but so far no luck. I spent some time looking for IC16581 but can't even find it on the SC board. I'm stuck, please help........
                                    • gdawg
                                      • Sep 2012
                                      • 170
                                      I would start a new thread. You came in at the tail end of malachi's repair and you will get a lot more help with a new thread.
                                      • iddomilan
                                        • Feb 2016
                                        • 6
                                        Good call, here's a link to the new thread: TC-P55GT30 6 blinks
                                        • riparo
                                          Panasonic Oled 55EZ950E, no picture, red led blinking every 4 sec
                                          by riparo
                                          Hi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
                                          I attach a link to download the service manual, thank you for anyone who can help me
                                          https://tel-spb.ru/download/?brand=P...0E_LA73.rar​
                                          01-11-2024, 12:35 PM
                                        • CoinCoin88
                                          Panasonic PF50G20S blinking 13 times
                                          by CoinCoin88
                                          Hello there,
                                          Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
                                          Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
                                          06-30-2023, 05:43 AM
                                        • Andre Gilbert
                                          by Andre Gilbert
                                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                                          11-20-2024, 08:52 PM
                                        • ItepK
                                          Panasonic TX-P42G30E green light blinking, no video, no audio
                                          by ItepK
                                          Hey everyone!
                                          I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
                                          This post describes my entire troubleshooting process of this TV.
                                          When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
                                          I've taken the unit apart, and I've started to check some voltages:
                                          • On the P11 connector, there is 15V DC only for a brief moment, then it goes
                                          12-22-2023, 05:06 AM
                                        • Tof
                                          Panasonic Oled TX-65FZ800E, no picture, red led blinking every 4 sec
                                          by Tof
                                          Hello everyone, here is the issue I am facing with my Panasonic Oled TX-65FZ800e.
                                          When the TV has not be used for some hours, I power up the TV with a video input and the image is displayed perfectly for 30seconds and then the TV switch off with the red light blinking every 4 seconds for ever.
                                          The service manual explanation: EVDD_SOS (EVDD 24V error) with check point (oled panel, P board, A board, T-CON)
                                          I opened it and found a burned connector on PB-board on the 24V pins.
                                          The 24V wires have change a bit of color due to the overheat and the corresponding...
                                          02-01-2022, 03:18 PM
