Vertical Lines and Black Screen on Samsung HPT5064X
  • wilmer007
    • May 2014
    • 10
    hello. my mom's HPT5064X is giving her problems and i asked her to bring it to me to see if i can get it fixed.
    i turned it on and quickly saw some vertical lines and the image was a little distorted aswell. but then the tv quickly went completely dark black. so i kept turning it off and on and nothing. so i said "ok i'll leave it unplugged and try again tommorrow". however now i just went to check and it still stays dark. the tv turns on normally since i can hear it turn on, however it just stays completely black and using the remote to go to menu or change sources does nothing.
    what can the problem be or is this completely unrepairable?
    Edit:
    i also opened it up and checked all the capacitors (common problem on these old Samsung HDTVs) and all the capacitors still look brand new and working so i know i don't have to replace the capacitors yet.
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Vertical Lines and Black Screen on Samsung HPT5064X
    Can you post some pictures of the boards?
    Black lines and distorted image is either lcd failure or a bad t-con.
    Use a flashlight and see if you can see an image on the screen. Can be the backlight thats failing also.
    • wilmer007
      • May 2014
      • 10
      thanks for the quick reply.
      i used the flashlight and still got nothing on the screen.
      as for the boards they all look fine nothing appears to be burned or anything from what i can see but i can take some pics if you still need me to.
      • wilmer007
        • May 2014
        • 10
        bump
        • tw2005
          • Oct 2011
          • 6458
          Fellas, you can forget the flashlight. It's a plasma TV.
          Common issues are power supply faults, like bad joints on the Va and Vs FETs or they actually end up blowing , going short and the fuse will be gone too.
          Or and potentially since you say lines and distortion , now nothing. The upper buffer board shorts, often the ICs burn and it's visisible and the Ymain board usually goes with it and the 88N30W FETs are shorted and sometimes more.
          It's a pretty old Samsung and you'd be lucky to find boards, maybe get them repaired but probably not an economical choice.
          Try searching the model or board numbers. there were plenty of models that had the same boards, same faults, sound, no picture.
          • wilmer007
            • May 2014
            • 10
            ok so how do i find it which of the boards is the problem?
            they all look fine to me and nothing looks burned on them.
            is the tv repairable?
            cuz my mom wants to call like 3 different tv repairman and i told her to wait to see what i could do.
            • RCA2000
              • Sep 2014
              • 111
              Perhaps you should read some of the "plasma tutorials" on this site...to get an idea of how a PDP works..
              LIKELY...you have a Y-sustain issue or buffer boards or BOTH. OVER 70% of ALL PDP problems end up on these boards. Not too mention too often ONE will kill the OTHER. In the days when these sets were NEW..we were OFTEN asked to replace ALL of the "scan boards" as a SET__Y sus, bufers and Z or X sus(depending on what the MFG called it) .. NOW ..one has to narrow it DOWN..
              If you are NOT getting you VS voltage to the Y sus board--THAT Is likely the problem...but MAYBE not ALONE.
              Look for larger transistors on sinks on this baord. (either MOSFET or IGBTS' ) and see if ANY are shorted. ALSO..if you see a large black square thing under a large sink--that is called an "IPM MODULE" and they OFTEN go bad..) There ARE new ones on ebay...BUT they are NOT easy for even a PRO to remove.. SO get a rebuilder if your set uses these...on Ebay once again.
              SOME PICTURES of the boards might help ehre...
              • wilmer007
                • May 2014
                • 10
                that all sounds complicated and me and her both agree that if it gets too complicated to not bother wasting our time when a brand new 43" 1080p HDTV start at like $250 for LG, Sony, etc..
                we already said we are never buying Samsung ever again(we bought 5 Samsung HDTVs over the last 7 years) because this is the second Samsung we have issues with (my 46" Samsung had bad caps and i was able to somewhat fix it) so if she calls the tv repair guys and tell us any price that is too high we will just buy a new set.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  No no ! Why trash it you have not even bothered with it yet ! Upload some images of the fault please.
                  • wilmer007
                    • May 2014
                    • 10
                    sorry i haven't responded right away. i was waiting for the voltimeter to arrive to do some testing on the tv. here's 3 pics of the y board. two of the capacitors appear to be leaking and not blown yet, so those have to do replaced but they don't appear to be the issue because the tv wouldn't even stay turned on if it was a capacitor issue.
                    the board itself looks fine though. nothing else out looks out of place.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Watch this might be a bit if help:
                      https://m.youtube.com/watch?v=JjQ--2SZdyY
                      • wilmer007
                        • May 2014
                        • 10
                        i'm still confused.
                        i'm a complete newbie when it comes to fixing a tv. it was hard enough just to figure out that the other tv was failing because of bad caps and i had my dad solder the caps in and we somewhat fixed it as that one still acts up every once a while and have to unplug for it for a few hours for it to fix itself.
                        i think the best thing for us to do is to take the boards to a local shop and have them look at everything and give us a price estimate to repair these boards before we decide if fixing this tv is worth or simply just buying a brand new set that is not brand samsung.
                        cuz i have no clue what to look for or how to fix. and i don't wanna risk getting shocked with the tv plugged in trying to check the voltages and stuff just to save a few bucks.
                        the only thing i was able to do was check the two fuses (one on the Power Supply and the other on the Y board) and they both read around 0.06 so they are not blown.
                        • wilmer007
                          • May 2014
                          • 10
                          took it to a local shop for a free diagnostic and they said it was the tube. i'm guessing he meant like the lcd screen perhaps. anyways he said the part is not available so i guess we have to get a new tv.
                          • Stanley1843
                            Screen Display Vertical Multicolor Lines
                            by Stanley1843
                            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                            06-29-2024, 11:54 AM
                          • Kambi13
                            Samsung LE32C530F1W with vertical lines on Screen
                            by Kambi13
                            Hello all, I'm dealing with a Samsung LE32C530F1W that now has vertical lines on the right side. It started with a ghost image on the top of the screen and then I tried the old trick of masking a few contacts in the flat cable that connects the T-Con board to the screen with some tape. It worked for a while and now out of the blue it turned into what you can see in the pic. I was able to get my hands on a known good T-Con board but the problem still persists. Now, what I've noticed is that the cooper colored flat cables that are directly connected to the screen itself are very hot to the touch...
                            09-15-2022, 07:48 AM
                          • ItalianSat
                            LCD SAMSUNG LE40A656A1CXXE - Vertical Lines on Half of The Screen?
                            by ItalianSat
                            Hello Everybody,
                            I have a 40 inch LCD SAMSUNG LE40A656A1CXXE. Its problem is that there are Vertical Lines on Right Half of The Screen.
                            Interestingly enough, when I move my mouse (in the case if connected to a PC) or when I am watching the TV, lines also move. At first appearance, I had thought that the problem might arose from loose vertical ribbons (COF), but when I opened up the TV for further investigations, I realized that the problem cannot be solved by touching them.
                            Moreover, I detached the T-CON board for a new round of investigation. I personally...
                            06-28-2022, 06:02 AM
                          • Firentiosi
                            1/3rd of screen black with occasional vertical lines - repair attempt for learning! - Kogan KALED58RT9220SVA
                            by Firentiosi
                            Thanks for offering your assistance with this. I'm an electronics enthusiast with moderate level of competence (have a decent lab with two power supplies, microscope, DSO, hot air, good iron, can competently work at a component level on SMDs, design and solder own PCBs etc). I really enjoying fixing things and learning new stuff so took up a free 58" LED TV and have been googling and watching Youtube videos to see if I can fix this! I am happy to go down to individual component replacement/strip replacement etc - it's all in the name of learning.
                            The issues are as follows: the...
                            11-27-2024, 12:33 AM
                          • Chrissygizmo
                            by Chrissygizmo
                            02-10-2025, 12:33 AM
