Vizio E320i-A2: Power on, on-screen logo, nothing else
  • volcano
    • Feb 2016
    • 4
    Hi all-- I'm new here (and relatively new to electronics), and I'm working on repairing a Vizio E320i-A2 unit that powers on (with both the onboard controls as well as the remote) but stays locked up on the Vizio logo that displays onscreen. The LCD and backlight seem to be fine-- the logo is bright and crisp. The unit does not respond to any input (IR or onboard) once it is powered up.
    So far:
    - The voltages from the power supply check out fine.
    - I've checked the voltage regulators on the mainboard and they all appear good. The LD1117 regulators output 1.2v and the GH16D outputs are 3.3v.
    - I've also read a culprit could be the EEPROM, or in this case, the NAND flash chip. From what I understand there's no real way to check this. In any event, I measured 3.3v for the supply voltage.
    Anything else I should be looking at or considering before I plunk down the cash for a new mainboard?
    There are two ICs labeled "D9329" and I believe they are the BD9329. One is located near the power supply input and the LCD data output, and the other is located near the MT5112EE chip.
    The first (by the PS input) measures as follows:
    Pin 1: 9.67v
    2: 12v
    3: 5.1v
    4: gnd
    5: .9v
    6: 1.68v
    7: 11.81v
    8: 2.67v
    The second is slightly different:
    Pin 1: 6.18v
    2: 12v
    3: 1.57v
    4: gnd
    5: .9v
    6: 1.44v
    7: 11.81v
    8: 2.65v
    I'm not going to pretend to understand exactly what these do other than step down voltage, but from looking at the datasheet and the voltages it seems they are consistent. The difference between pin 1 input is about the same as the difference on the pin 3 output.
    You can see a photo of the board here.
    Definitely appreciate any knowledge or suggestions-- it has been a good learning experience already, but it'd be even better if I could actually fix it instead of replacing the whole board
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Vizio E320i-A2: Power on, on-screen logo, nothing else
    I think that you have a problem with your mainboard. ( Memory failure ). You can try to reset the EEPROM and see if that helps.
    Tv turns on and stays on so power supply is ok. Backlight and colours are fine so the t-con and lamps/leds are ok to. I think replacing the mainboard will fix your tv.
    Ps , check all the caps after replacing the mainboard. They use cheap parts in these tv's.
    • CapLeaker
      Leaking Member
      • 8146
      The voltages measured don't mean much if we don't know what the pin out name is.
        Page 11 of the spec sheet tells you how to calculate what the output Voltage will be based on the known values of the two resistors connected to the FB pin 5 then you can tell if the circuit is putting out the correct Voltage or not.
          It looks like he is referring to the two buck converter ICs BD9329.
            BTW, SJ does not have the EEPROM for this model so it may not be the cause of the problems.
            http://www.shopjimmy.com/catalogsear...Vizio+E320i-A2
            • volcano
              • Feb 2016
              • 4
              Ah perfect-- I will look at this and report back.
              Right, this board uses a Samsung NAND flash chip instead of EEPROM. I've read that this is common (or maybe required) for smart TVs.
              Is it essentially a process of elimination to determine if that's at fault? In other words, is there a way to definitively check for corruption or otherwise any fault in flash memory? Just trying to get my head around the troubleshooting steps for something like this.
              Thanks for your help.
              • volcano
                • Feb 2016
                • 4
                I ended up ordering a replacement board off of eBay as the output voltage checked out using the datasheet from the BD9329. The new board fixed the issue of course, so I'm assuming it was most likely corrupt memory.
                Kind of a bummer for me I wasn't able to locate a specific fault (this was a learning project after all), but I'm certainly not going to complain about a working TV. I'm sure there will be many more
                • Bob1394
                  Vizio M65-C1 | Logo appears for 10 seconds then off
                  by Bob1394
                  I have used the search, and am stumped.
                  My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
                  I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
                  https://www.badcaps.net/forum/showthread.php?t=81088
                  https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
                  Observations
                  1) [Interaction] Power turned on via TV button (or remote)...
                  02-08-2023, 01:03 PM
                • Super360
                  Vizio E701i-A3 Vizio logo flashing then turns off
                  by Super360
                  Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                  07-25-2024, 07:06 PM
                • x_orange90_x
                  Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                  by x_orange90_x
                  I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                  12-28-2023, 06:26 AM
                • JaquesPratt
                  Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                  by JaquesPratt
                  I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                  This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                  07-16-2024, 01:04 AM
