Lg 60pv250 no picture
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Just got this today at what I thought was a good deal.
    Seller said it had sound but no picture.
    I'm not getting sound.
    The tv powers on, the red front led blinks when I change the channel or volume.
    What should I be looking for.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Lg 60pv250 no picture
    I've tried posting the pictures all in one post. For some reason I can't seem to get it right.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      3rd picture
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        4th
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          5th
          Reading up here it seems like a Zsus board problem. The lowest mofset, I think that is what it is called, on the lower right is bent almost at a 90 degree angle against the board.
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            Last one
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              This is with the zsus board disconnected.
              • Shinju
                • Mar 2014
                • 1239
                Check the soldier joints in the large cooper coils on that z board they are prone to cracking and high failure.
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  I've already determined that the ceramic fuse is blown and Q208, Q209, Q210, Q211, Q212 and Q213 are shorted. If I did it right. They were tested on the board. Is that ok or do I need to remove them?
                  With help from member Nick's tv's.
                  • Shinju
                    • Mar 2014
                    • 1239
                    Need to remove each IGBT for a proper test, I have repaired 2 of those panels (60PV450) and it's always been bad IGBT's caused by those inductors coil soldier joints failing.
                    One Zsus had SMD componates on the back side of the board blow too.
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      Thank you. I plan on sending it in for repair to Nick's.
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        Re: Lg 60pv250 black horizontal line
                        I got my zsus board back. The tv works now but now that I can see a picture, I see a thin horizontal line about 3/4 of the way down.
                        Inspecting the back I see a tiny tear in the ribbon cable from the display that goes into the buffer board.
                        I'm
                        Screwed right? I wasted $180.
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          I can't seem to attach more than one picture at a time.
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Dam thats a pain, unless your soldering skill is good you wont be able to fix that I was able to repair a 720p Plasma ribbon cable but was VERY hard to do.
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              Nope. Skill are rudimentary at best. I guess I'll have to part it out.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Dam, how did it happen ?
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  I don't know. I bought in from Craigslist, an American online selling community for $100.
                                  Owner said it would turn on, no picture but sound.
                                  He took the back off, didn't see anything wrong that he could fix. My guess is he tore the ribbon getting the back off or putting back on. The screws weren't even in the right place.
                                  I guess if there is a next time, I've learned to inspect the ribbons before spending money to fix it.
                                  Already sold the 50" Panasonic plasma that this was replacing.
                                  • Shinju
                                    • Mar 2014
                                    • 1239
                                    that Zsus will sell fast, that is the most common failure on the PV series panels and they are very scarce now.
                                    Bummer, you can try to see if you can find someone to fix that ribbon cable but yeah its a very hard task, can you get a close up shot of the tear higher res?
                                    • Malachi
                                      • Dec 2015
                                      • 1077
                                      • Usa
                                      • Malachi
                                        • Dec 2015
                                        • 1077
                                        • Usa
                                        I doubt I can get a better picture.
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
