Samsung LCD LE32R88BD switching itself off after 2-3 seconds.
  • Loz2212
    • Jan 2016
    • 61
    • United Kingdom
    Samsung LE32R88BD/ BN44-00155A
    Hi guys,
    I have a LE32R88BD.. pinched it off my friend as he was about to wang it in the skip. The TV turns on very briefly and then shuts off all together.. Not even a standby light until I press the power button again.
    I'm pretty confident with a meter etc but could just do with someone pointing me in the right direction.
    No obvious swollen caps or burns on any of the boards. Metered out most of the small fuses and checked the VCC on the inverter which remains at 24v steady even when the screen goes off. All small transformers along the inverter board have the same resistance (assuming that's measuring the resistance through the lcd as well?)
    Sorry if this sounds like a terrible explanation, I may require the odd prompt.
    Thank you
  • sordids999
    • May 2013
    • 2149
    Re: Samsung LCD LE32R88BD switching itself off after 2-3 seconds.
    Pictures ?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Two 1000uf caps under heatsink on mobo will probably be causing the issue. Common fault on them Bordeaux motherboards.
      • Loz2212
        • Jan 2016
        • 61
        • United Kingdom
        That's the only photo I've got on my phone at the moment until I go home tomorrow. Apologies for the rubbish quality.
        • Loz2212
          • Jan 2016
          • 61
          • United Kingdom
          Where's that Reecey? On the PSU or the logic board?
          • CapLeaker
            Leaking Member
            • 7964
            main board. Your picture the board on the very right.
            There is a metal shield / heat sink. Open it up and there are caps underneath.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Where is the covers for the Tcon and Inv ?
                No mounting screws for the Inverter board, at least he puts the screws on the T-CON board for GND.
                • Loz2212
                  • Jan 2016
                  • 61
                  • United Kingdom
                  I took the covers off to have a look. Should I not be operating the TV without these on?
                  • Loz2212
                    • Jan 2016
                    • 61
                    • United Kingdom
                    Thank you CapLeaker.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      My bad sorry. Also Sordids did one and has a thread on it I will link it
                        You can at least put the mounting screws in place during testing then put everything back in place after you are done, the shield on the T-CON may be used for the heatsink so you should put the shield back in place.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Check out this thread will help you alot:
                          https://www.badcaps.net/forum/showthread.php?t=49127
                          • Loz2212
                            • Jan 2016
                            • 61
                            • United Kingdom
                            The screws were in but I removed them so I could check the underside of the board. I'll put the cover back on the top one just thought it would be better for you guys to see if anything stuck out to a trained eye.
                            • Loz2212
                              • Jan 2016
                              • 61
                              • United Kingdom
                              Thank you Reecey. I'll check that out.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                No worries keep us updated
                                  09-07-2024, 05:50 AM
                                  by sam_sam_sam
                                  03-31-2024, 02:12 PM
                                • eigma
                                  Samsung UN40H5003 boot loop every ~8 seconds
                                  by eigma
                                  Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                  Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                  SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                  Main board: BN94-07592P / BN97-08922R...
                                  11-20-2024, 10:31 PM
                                  09-06-2024, 11:40 PM
