Power board BN44-00197a has 126v on hot section nothing on cold side. Have checked transformer and coils for continuity and OK . did replace 6 caps on top rhs of the low voltag e area although originals all look OK . the set apparently working normally was turned off but wouldn't start next day no light no clicking nothing. Board has no sign of any problem. Located in country Australia and components not readily available and prices for another board not justified these days. Have schematic and understand basics. Any experience of this problem appreciate your comments.
Samsung LA40A650A1F no 5.3v standby
Tags: None
Re: Samsung LA40A650A1F no 5.3v standby
So what DCV do you have between the two legs of the main filter cap?
What GND did you use to measure that 126V? Which test point is that that gives you the 126V: AC? DC?
It is impossible to have 126V reading on the power supply board, you must be using the wrong GND ref.Last edited by budm; 01-26-2016, 08:27 PM.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Thank you for reply. CP802 and 803 side by side read 343v DC. I only have phone to put up any photos and not the best camera!!Comment
Was using board as earth sorry. Now 126v DC on DM801 as measured between grey side of it and neg leg CP803.Comment
So you do have Voltage to run the stby power supply, the fuse F801 T3.15A is good.Never stop learning
Hi yes FI801 good. The voltage certainly on hotside
Caps on 5.3v line seem likely but replaced and as well this wasn't the usual thing with warnings etc just went from good to bad overnight.Comment
Do you get stby Voltage if the main board is not connected to the power supply board?Never stop learning
No joy with that. I also jumpered pins 1 and 3 just in case but no luck. How do I test DM805 on the heatsink? In circuit? My experience was really with valve TVs when the screen virtually told us what was wrong. Did transistors as well but only recent mucking about with success was with self evident faults such as bad caps burnouts etc. I do this now rather than scrap an otherwise good unit and if they go pass them onto other old fogies who appreciate the bigger screens.Comment
You check the Diodes DM801, DM803 whci are for the switched 13V, DM805 for the STB5.3V use Diode mode on the meter and also test with Ohms mode, no need to remove them unless the readings look bad.
You also need to check ZDM802, ZDM803 Diodes, the caps CM802, 814, 815 capacitance and ESR.Attached FilesNever stop learning
Thanks again. I have concentrated on output side because of 126v DC to earth reading at jumper RM801 and now note that is a minus voltage and i really have no idea what the voltage should be at that jumper. Caps you mention are rated 50v. Will try and get diodes checked difficult to get at some.Comment
The hot side is floating at 150 odd volts with ref to chassis. For hot side checks use filter-cap neg term as neg for meter.
Cold side will give usual readings ref to chassis....TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
Been busy watching Aussie Open tennis etc!! Do not have any vcc at all by looks of it as no voltage of any type on ICM802 or following components inc DM806. The 126v is on ICI806 and CI822 ref to filter cond leg. Half components are embedded in board and these include overload circuit. Will keep working back.Comment
you cannot use the chassis GND as the GND ref when making the DCV reding in the HOT side of the circuit, you need to use the Negative leg of the main filter cap as the GND ref for your meter.
So what DCV do you have between the two legs of the main filter cap in the HOT side of the circuit? around 325VDC? We need this Voltage first.
You need to concentrate in the STBY power supply section first.Last edited by budm; 01-29-2016, 05:58 PM.Never stop learning
Measurement on main filter caps is 343v but can't get any readings on input side of standby circuit as stated above. No vcc from ICM nor any reading on any of the 8 legs. Now trying to trace back to other components earlier in circuit to see where voltage stops - should there be about 15v feed to the standby circuit and could brown out circuitry affect? Just trying to get a handle on basics but lack of test points and voltage info not shown except for 5.3 and 12 audio.Comment
You said fuse FI801 is good, then you should have 343VDC with ref to the Negative legs of the main filter caps of either CP802 or 803, that fuse (page 3) feeds the Voltage to STBY transformer TM801 pin 6, so you should verify if you have the DCV on pin 6.
ICM802 STBY SMPS IC ICE2QS01 HV pin 4 and 5 are the startup Voltage receiving pins, what do you have on that PIN?
What do you have on VCC pin 7 which the cap CM814 is charged by by the HV pin until it reaches the VCC ON THRESOLD of 22VDC for the circuit t start up, onec that happen the AUX winding (PIN 1 ,2) of the TM801 will provide the running Voltage.
See diagram page 2 and 3 to see how it works.Attached FilesLast edited by budm; 01-29-2016, 09:06 PM.Never stop learning
There is 343v DC on DM804 so it seems that section to transformer is OK. But nothing to any pin of ICM802 which picks up its voltage from PFC via 3 in line resistors. Has the ICM gone bad as I would think input voltage should be readable at least if some other component after it was bad.Comment
So the resistance of those three 3.9K resistors connected in series to provide the 22VDC start up Voltage to pin 4/5 are OK? Check the resistance between HV pin 4 and the GND pin 8 to see what resistance you are getting, it just a simple Voltage divider to drop the 325VDC (230vac x 1.414 = 325VDC on the main filter cap), you AC line Voltage must be higher than 230VDC for you to have 343VDC on the main filter cap, your meter is OK and in calibration?Last edited by budm; 01-30-2016, 12:03 AM.Never stop learning
Thanks to you getting somewhere now. First two resistors read spot on the third reads open circuit! Not used to these embedded components the good ones have a very small black block in between ends third one nothing. No reading between pins 1 and 8 on ICM. Over here we are nom 240v ac .Comment
Great, we just need to get that startup Voltage to that IC running.Never stop learning
I will check a couple of boards I have to see if there is a close match I can solder onto the PCB and then advise the result - here's hoping!!Comment
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
What I already found is that the 12.8V are not an the connector to the main board connector to the power... -
by Kaar3lTV: Samsung QLED QE65Q7FNAT
PSU: BN4400940A
MB: BN94-12832K
I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r... -
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
