Scepter X322BV LCD backlight issue
  • Nick's Tvs
    • Jan 2014
    • 621
    Backlight issue
    Backlight won't turn on fully and I have never seen this type of symptom.
    MIP320FL-2 has connector CN3 doing some really weird things.
    When I tap that cable coming out, the back-light activates for a split second, but then goes away. I looked at the connector joints and they were good. I re-flowed half the board anyway with no change in symptoms.
    If you take a look at the first picture, you can notice that only a part of the back-light turns on. I checked every wire to make sure it had good continuity, I checked all the solder joints on the board and re-flowed, I made sure all CFL tubes had proper contact. I still don't understand how touching that wire and messing with it makes the cfl's turn on 75% for a split second. I tested in and it has 0 ohms of resistance. No clue what I am missing here.
    Honestly don't work on Scepter tvs often, so just not sure what is going on.
    Any help is appreciated.
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: Scepter X322BV LCD backlight issue
    Alright well, about to exceed the time limit on this set. Just going to replace the entire board and update later. Hopefully once I get the new board ill be able to compare readings and figure out the original issue with this board.
    Will keep the forum updated.
      Are the ground return wires of the CCFL connected back properly? It looks like they are not getting enough high Voltage or the return wires are not connected.
      • Nick's Tvs
        • Jan 2014
        • 621
        the return wires of the CCFL? There are only 2 wires seem to go to the CCFL on each side, no other wires.
        Also SJ board came in and didn't fix the issue. Unfortunately I did the classic mistake of listening to my customer about what was wrong with the tv.
        Originally this set came in 4 months ago or so with no back-light. Same thing I don't work with scepter TVs so I just got a new board for it and gave the tv back to the customer. Since the tv had similar symptoms the customer told me we had the same issue again and need the board to be replaced again. I don't remember if the first time around I had just a little back-light or not, so I just assumed I did, but clearly something else is going on here.
        Just to make sure, but the main board couldn't cause this issue right? If it did wouldn't it just be similar to the problems the vizio tvs have with the EEPROM going out and causing the back-light not to engage at all?
        • woodman45
          • Aug 2015
          • 87
          • U.S.A
          I know this thread is old. Did you ever figure it out? I have same model no back light at all. Blue power light comes on & you can see image with flash light.
            • 12145
            • U.S.
            also trying to figure this turd out, have some of the usual bad winbond chip symptoms, tv won't tune channels, remote turns on blue led on front but doesn't change channels or anything, button board doesn't respond, get tv to come on after many attempts but as soon as turn it off won't turn back on, winbond chip is 25q32fysig, was looking at datasheet and see a reset on pin 7, does that mean I can reset it? or would that do any good?: https://www.datasheetq.com/pdf-datas...c-Winbond.html
            • Cornito
              Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
              by Cornito
              Hello Team,
              I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
              Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
              Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
              08-08-2024, 08:09 AM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
            • Cornito
              TCL 65C715 backlight issue
              by Cornito
              Hello team,
              I'm back with another topic.
              It's a 65C715 TCL tv with backlight issue.
              But the problem is a bit strange.
              When I took this tv from the marketplace backlight didn't work but picture was ok.
              Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
              Putting all back together the tv worked fine for weeks. => Contact issue??
              Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
              06-09-2024, 02:24 AM
            • shellybelly
              Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
              by shellybelly
              Back Story
              I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
              So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
              08-27-2023, 10:40 PM
            • Riananyaina
              MacBook A1708 820-00840-A backlight issue
              by Riananyaina
              Hello Everyone ,
              today I'm coming to you regarding my issue which is no Backlight .
              I have image on my screen but no light .
              The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
              First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
              Please find below few informations which can help for the analysis...
              04-24-2023, 05:03 AM
