Faulty transistor in a Samsung TV Main Board
  • PatrickSaw
    • Nov 2015
    • 20
    • Spain
    Hello!
    I have a Samsung TV UE32C5100QW. Main board: BN41-01549C.
    Fault: Dont power ON, unless you insist a lot.
    I've located a bad transistor, and if I heat it, TV power ON fine.
    Transistor is marked like: 72C, and in the board: D1201.
    How I could find this transistor model, to buying the same and replace it?
    You can see it here.
    Thanks in advance!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Faulty transistor in a Samsung TV Main Board
    Hmm its unlikely the transistor at fault. Ive seen that these boards have issue with broken Bga solder joints so yours might be as well as it becomes heat-sensitive. I would say you might need to reflow your board.
    • tw2005
      • Oct 2011
      • 6458
      well if it's labelled D1201 it's a diode and if you have a decent multimeter you should be able to check if it's functional or not. How are you heating this up to keep it localised and be sure it's this part?
      In the meantime I'll see if I can find a possible match for that code
      • PatrickSaw
        • Nov 2015
        • 20
        • Spain
        Well well. I've listened you, and I checked again: focus heating in D1201... MEC!!, TV dont turn ON. Maybe yesterday I was tired... but it was a big mistake. A good focus heating, and I've found the fault: IC AOZ1031AI (in the pic, to the left of the word "LARGE"). I've replacement for this, so I win.
        Detail faulty:
        1) Dont Turn ON. Fixed red LED
        2) Heat in IC Z1031AI
        3) Power ON right
        4) Switch OFF >> ON
        5) Again step 1), with fixed red LED
        I expect this helps someone.
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
        • mrautom8
          Samsung TV UN75H6350AFXZC main board schematics?
          by mrautom8
          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
          While relay is on, all voltage rails are present and steady (scoped) on main board.
          I love a good logic puzzle but getting lost without any schematics.
          No shorts on ANY capacitor main board.
          Thermal camera shows 3.3V inductor getting warm instantly but...
          10-19-2025, 06:32 PM
        • Dani_2024
          by Dani_2024
          10-28-2024, 05:06 PM
        • Lee M.
          Samsung UN75RU8000FXZA bad main board?
          by Lee M.
          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
          11-08-2023, 07:46 PM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
