Vizio V0370M Backlight no Picture
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Hello everyone, so glad glad you're back. I picked this up last week and like the heading says, it fires up, logo goes from amber to white and backlights come on.
    I checked voltages at psb connectors and here is what I get:
    6 pin connector:
    #1- 3.11v
    #2- 2.96v
    #3- 0v
    #4- 0v
    #5- 0v
    #6- 0v
    12 pin connector:
    #1- 1.53v
    #2- 12.2v
    #3- 12.2v
    #4- 12.2v
    #5- 0v
    #6- 0v
    #7- 0v
    #8- 0v
    #9- 0v
    #10- 5.05v when plugged in or turned on
    #11- 5.05v when plugged in or turned on
    #12- 5.05v when plugged in or turned on
    Only getting .02 volts at T Con fuse.
    Checked 1117 regulators on front side of main and here are readings:
    U2- in 4.95, out 3.27
    U4- in 5.0, out 3.28
    U5- in 4.95, out 2.61
    U8- in 3.24, out 1.24
    U9- in 4.95, out 2.50
    The Main board # is 3637-0512-0150 (0A) which I have been unable to locate.
    Any help would be appreciated, Thanks
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    Re: Vizio V0370M Backlight no Picture
    Haven't gotten any feedback on this so thought I would do some attachments since it is up and running. Thanks
    • whiz62
      whiz62
      • Dec 2013
      • 242
      • usa
      Just wanted to let all know it was the Main board. Working fine now.
        Thanks for the follow-up on the repair.
        BTW, when reporting the DCV of the LDO regulator (1117), always provide the DCV of the ADJ/GND pin too.
        • whiz62
          whiz62
          • Dec 2013
          • 242
          • usa
          I thought about that after the fact. Will do from now on. Thanks.
            You can tell if the regulator is bad by measuring the DCV between ADJ pin and the Output pin, it should be = to the Vref which is 1.25V.
            The output Voltage should be = Vref of 1.25V + Vadj pin. (as long as the input Voltage is not below the min Vin requirement).
            https://www.badcaps.net/forum/showth...999#post300999
            • csmith
              Vizio D50u-D1 Powers up no picture
              by csmith
              I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
              Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
              supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
              issue. Set will power up with remote but not power off....
              07-11-2025, 11:52 AM
            • gavric
              Vizio M70-C3 Half picture is bad, main board on its last leg?
              by gavric
              Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
              When tv powers on vizio V logo shows nice on whole screen. picture 1
              When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
              When i start youtube picture shows on left side fine, right is all scrambled. pic 2
              When i click video to start playing picture goes black(like when you change...
              09-02-2021, 08:55 PM
            • ggil44
              Vizio M65-E0 No Picture, No Sound
              by ggil44
              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
              09-03-2024, 08:30 PM
            • maricm
              Vizio m65-c1 picture flashing on and off on the screen
              by maricm
              HI all,
              hope someone point to the possible issue before I start buying replacement parts.
              Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
              Backlight stays on all the time,
              Sound works fine.
              screen keeps changing form black to full picture in about 1sec intervals.
              Picture looks fine with no visible artifacts.
              I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
              Disconnecting left and right ribbons on...
              11-25-2023, 06:32 PM
            • Fly_Among_Stars
              VIZIO E70-E3 Half picture with half TCON
              by Fly_Among_Stars
              I have a VIZIO E70-E3.
              Symptoms: Black screen, no picture, but LED backlights are working.
              I probed the power board and voltages are as listed on the board.
              Main board appears fine, too.
              I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
              There are two separate ribbon cables feeding the LCD.
              If both are connected, the screen is black.
              If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
              04-24-2023, 08:20 PM
