Vizio E422VL-completely dead
  • bhughes2912
    • Dec 2015
    • 10
    Need some help troubleshooting this vizio. The set appears completely dead with no Logo light and does nothing when pushing the power button. I have done some tests. The power supply appears to be working correctly. By isolating the power supply, I get the 5v standby. Once I connect only the mainboard to the power supply, I get 12v along with the 5v. The weird thing is the mainboard sends 2.2v on the power on/off pin even before hitting the power. That is why I have 12v before powering up the set. I have checked the voltage regulators and they function correctly. I am looking for ideas on troubleshooting this LCD.
    Thanks in advance,
  • bhughes2912
    • Dec 2015
    • 10
    Re: Vizio E422VL-completely dead
    Hi Everyone,
    Its been a while since I posted this. Has no one ever experienced this problem or know where to focus my testing?
    • CapLeaker
      Leaking Member
      • 8327
      So what you saying is that the PSon signal from the main board is "stuck on", but yet the TV won't power up? Looks like a main board problem to me.
      Try unplugging the IR board?
      • bhughes2912
        • Dec 2015
        • 10
        Hey CapLeaker,
        That's a good way to put it, its "stuck on" but will not power up. I agree with you, its the mainboard. I have shorted the PSon and backlight on with 1k resistors and the backlights came on. So, I figure that rules out the PS. I have tried unplugging everything except the PS and nothing changes. The fuses on the main board check out. The voltage regulators also check out. I am stump with this one.
        • CapLeaker
          Leaking Member
          • 8327
          There is a eeprom to be had at SJ, but it doesn't mention that symptom you have. So I guess you should look for a new main board.
          You also could try heating (hair dryer) or cooling (can of air upside down). Freeze the eeprom, see what happens.
            Originally posted by capleaker
            there is a eeprom to be had at sj, but it doesn't mention that symptom you have. So i guess you should look for a new main board.
            +1
            • Agent24
              I see dead caps
              • Oct 2007
              • 5037
              • New Zealand
              Or there is some problem with PSOn signal generation circuitry on mainboard, shorted transistor perhaps?
              -David VanHorn
              • justice171
                Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                by justice171
                I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                1. Verified that all critical voltages are present:
                  • 3.3V and 5V are always present if DC is plugged.
                  • 1.8V on the BIOS chip is present.
                2. Checked the power button functionality:
                  • When pressed, the voltage drops to 0V, indicating the button is functional.
                3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                  • Confirmed connectivity is intact, ruling out issues
                11-26-2024, 12:39 AM
              • Andreas_de
                Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
                by Andreas_de
                Hello!
                i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
                Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
                Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
                04-12-2025, 10:38 AM
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • dragon3x
                >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
                by dragon3x
                Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
                that is still quite new, as it worked OK for some months until it failed.
                At the time I was not into power supply electronics; it was put
                aside and a new power supply installed inside the computer. Also at the time
                power supplies were half the price of today's.
                On the PCB there are a D339 and 7500B chips.
                I have found that schematics with these 2 chips (see included file).
                Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
                Some measurements,...
                06-05-2024, 03:34 PM
