Samsung UN60EH6003f LED TV issue
  • makeuler
    • Jul 2013
    • 5
    Hello everyone. I was hoping someone could help me figure out what is going on with this TV (Samsung UN60EH6003). I do not have a picture but do get sound and backlight does work. I purchased a fix kit for this tv and swapped all three boards from a cracked screen kit, but having the same issue. I am thinking possibly is a bad panel or the kit had a bad T-Con board in it, even tho the buyer said it was tested and 100% working. I do not see anything other then the glow from the back light on the TV screen. No Menu or faint picture. If the Panel is bad, will it typically be completely black? Any suggestions? Thanks Mike
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Samsung UN60EH6003f LED TV issue
    I would say bad panel, seen a load of Led Tv's with sound, no image with backlight which have been failed Lcds. Have you checked the tab bonds ?
    • makeuler
      • Jul 2013
      • 5
      No i have not, i will check tonight. Thanks
      • Kjell
        Samsung Series 9 - BIOS issue
        by Kjell
        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
        08-01-2025, 09:15 AM
        09-07-2024, 05:50 AM
      • vincentedel
        Samsung SyncMaster 740n Phase Control Issue
        by vincentedel
        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
        04-22-2025, 12:33 AM
      • Manucsl
        QE65Q800TATXXC Samsung TV Issue
        by Manucsl
        Hello.
        My TV is a QE65Q800TATXXC Samsung TV.
        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
        Any ideas to check would be very appreciated 😊
        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
        02-19-2025, 07:47 AM
      • FourRunner
        Display issue Samsung TV UA65JS9000W
        by FourRunner
        I purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...
        10-03-2024, 07:05 PM
