LN40A550P3F - help resurrect?
  • mpadilla
    • Dec 2015
    • 24
    • US
    I was given this Samsung LN40A550P3F tv. I was told it had multiple problems before it "died". Sometimes not responding to power. Getting vertical colored lines in picture. Sound going in and out. I opened it up and could see visible scorch marks on IC1203 on main board BN41-00975B. I haven't been able to locate the schematics yet for the power supply or main board. I disconnected the boards and connected the power and the power supply has a high pitched whine coming from it, so I disconnected it. It is model BN44-00197A. budm helped me resurrect another tv in this series which my daughter really appreciates! Following on that advice I have already replaced c102 on the main board.
    I wasn't sure where to start with the power supply...is it ok to keep plugged in with that whine and still take readings? Can someone guide me on troubleshooting the power supply and identifying what parts needs replacing on the main board? As I previously stated I already replaced c102 on the main board. I've seen this link from shopjimmy, but can I purchase the components separately and for less? I've uploaded pictures of the two boards. I'm ready and willing to take my time testing and learning; provide additional photos/information as needed; and solder anything necessary. Thank you so much!
  • mpadilla
    • Dec 2015
    • 24
    • US
    Re: LN40A550P3F - help resurrect?
    Looks like D204 is scorched on the main board as well. I located the parts list and perusing now.
      That Blew up IC is the Class D amplifiers IC.
      • mpadilla
        • Dec 2015
        • 24
        • US
        That would totally explain the audio issues. I found it for $7.00 on ebay. Anywhere to find it cheaper? Now trying to identify D204 and IC101.
        But then there's still the problem of the power supply. Any suggestions on testing it? My concern was the high pitched whine coming from it when it was plugged in.
        • mpadilla
          • Dec 2015
          • 24
          • US
          Found the power supply schematic. BN44-00197A. see attached.
          • mpadilla
            • Dec 2015
            • 24
            • US
            Sorry folks been away for a while as my spouse had brain surgery. Consider this one closed as I finally got around to removing the IC and one of the inductors and I don't want to go as far as repairing the pads. They were scorched in three spots on the IC and came out. Same thing with the inductor. So I'm just going to sell the board as is for someone else who is well versed in repairing down to that level.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Hope your wife getting better.....sorry to here this
              • mpadilla
                • Dec 2015
                • 24
                • US
                Thank you Andrew. She is doing well now. Missing hair and large scar but no cancer and improving daily!
                • cheeky2
                  by cheeky2
                  05-25-2024, 03:27 AM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • JSin21
                  Compatibility of main boards between different variations of samsung MU6100
                  by JSin21
                  Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                  I have Samsung Smart TV UA65MU6100WXXY version DA01
                  Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                  11-27-2023, 04:54 AM
