Toshiba 40rv525U no audio
  • erskine
    • Jan 2014
    • 20
    • barbados
    Hi , i have this Toshiba 40RV525U with no audio.
    It was making a loud noise from the speakers when first turned on.
    I re soldered some cold joints on the power board and the noise stop .
    now its totally muted except for the little blup u hear when it powers up.
    The speakers are good and i am usind an antena as my input with a good picture ,
    thanks in advance for any help.
  • sordids999
    • May 2013
    • 2151
    Re: Toshiba 40rv525U no audio
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Hearing that 'BUP' noise means at least the speakers may be OK. Look again at where you soldered cold joints. See if anything might be touching that should not be. Yes please post pics of the boards.
      • erskine
        • Jan 2014
        • 20
        • barbados
        took some pics but dont no yet how to post them
        • sordids999
          • May 2013
          • 2151
          next to post quick reply choose Go Avanced then look for manage attachments in there you can post pictures then upload them
          • erskine
            • Jan 2014
            • 20
            • barbados
            hope i got it right sending the pics
            • samson7point1@yahoo.com
              Help troubleshooting an audio problem with an RCA SGT-250 CED Player
              by samson7point1@yahoo.com
              The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
              The player processes the audio signal using two different reference frequencies. The "R"...
              04-30-2024, 11:22 AM
              09-06-2024, 05:27 AM
            • televizora
              HP 8470p - distorted sound and noise when playing audio
              by televizora
              Hello.
              I have an issue with HP 8470p - rather strange one.
              I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
              Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
              Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
              12-31-2021, 10:25 AM
            • String2016
              TOSHIBA L755 NO audio problem
              by String2016
              I have here toshiba l755 laptop the problem is no audio device detected on windows tried installing drivers and tried also replacing audio chip still same issue. anyone encounter this please help
              03-04-2023, 01:58 AM
              09-06-2024, 05:59 AM
