ps43d450a2w screen issue
+ More Options
Posts
  • comptek
    • Aug 2013
    • 606
    Hello everyone Happy New Year!!
    i just picked this Samsung ps43d450a2w everything seems to be working just that after a few mins the screen slowly gets covered in red/blue dots then seems to get yellow patches on it, i have tested and reset VA VS & VSC voltages as per label on panel, also inspected and resoldered any dry joints on power supply and on y-sus that connects to buffer board...
    any ideas please
    Kind Regards
    Gary
  • sordids999
    • May 2013
    • 2158
    Re: ps43d450a2w screen issue
    Have u tried increasing VS by 4-5 volts to see if this helps
    • comptek
      • Aug 2013
      • 606
      yes i have just tried 4v then 5v and still the same any other suggestions ?
      many thanks
      • comptek
        • Aug 2013
        • 606
        also example if menu is on then closes tha image is still there for a while !
        • comptek
          • Aug 2013
          • 606
          Well i think i have done it i tweaked vscan up a tad about 5v and its cleared will this cause a problem ???
          i was wondering if it was a weak cap doing it ?
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Doubt there'll be a problem--wont be a cap providing the voltage was right to start with--All you have done is compensated somewhat for old/aged panel. How long it'll last is anyones guess.
            TELEFIX
            • comptek
              • Aug 2013
              • 606
              thanks Alastair its only just 4 yrs and 3 months old lol but hey ho!
              • comptek
                • Aug 2013
                • 606
                well its still being a problem i have put all voltages back as they were and took a video,
                when the voltages were tweaked up it worked fine and then when cold it was back so tweaked the vscan again and from cold perfect when it got hot it started to come back again
                video below its like temp screen retension ?
                https://www.youtube.com/watch?v=AY8MiMaQQvc
                • comptek
                  • Aug 2013
                  • 606
                  hi again
                  any suggestions please about above video image retension ?
                  regards
                  Gary
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Im slightly baffled buddy, would need the set here with me. Maybe Xmain maybe firmware, have you tried firmware ?
                    • Alastair E
                      Chief Womble
                      • Mar 2013
                      • 1963
                      • U.K.
                      Hmm....
                      Has the control-board ever been out/replaced?
                      Reason I ask is the temp of the panel is monitored by control-board and timings/etc altered to compensate for gas-pressure variations.
                      LG use a thermistor chip thermally coupled to the back of the panel by a dead-toad.
                      Sams I'm pretty sure do summit similar but how not off top of my head, sure...
                      TELEFIX
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        With these sets Alastair im sure I read somewhere that the firmware doesnt clock the timings correctly and doesnt adjust to the proper drive methods for the panel but normally that causes pink banding so im unsure on this one.
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          Can you try a different image like normal instead of dynamic? This because your pushing the panel to the max on dynamic with contrast at 100%.
                          Try image setting on normal with a lower contrast , like 60/70.
                          Im curious if the same symptoms occur.
                          • Moreno83
                            • Jun 2014
                            • 2008
                            • The Netherlands
                            Im saying this because i get a little sparkles on my VT50 when i use dynamic with contrast 100 and brightness 60/70.
                            • comptek
                              • Aug 2013
                              • 606
                              ** Reece, i upgraded the firmware off of samsung site no difference,
                              ** Alastair, no control board has not been changed, Yet lol, it happens from cold so could it be faulty ???
                              **Moreno83, i will try that cos im sure it made things worse when put on dynamic :/
                              thanks for your input guys
                              i was tinkering yesterday i used a hair dryer on the y-sus board i gently heated up the bit where the yellow transformer and it got worse put it cool and the picture reverted back to just being bad, it did make a differnce when vscn was tweaked up a bit but then started acting up when it was on for a while... so could this mean an issue on the y-sus ?
                              • wizard13
                                Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                by wizard13
                                I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                • Part Number (P/N): PYU13E-00C00PFR
                                • Serial Number (S/N): 22028896H
                                • System Configuration (SC): A1PYU13E1127
                                • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                • Power Input: DC 19V –
                                02-28-2025, 02:43 AM
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
                              • cloudy
                                HELP - Contrast/brightness issue with subtitles on screen
                                by cloudy
                                Hi everybody
                                Since day one I'm having an unpleasant contrast/brightness issue on my Asus laptop.
                                Basically while watching movies, if subtitles appear on screen, the contrast or the brightness of the entire screen increases a lot (not sure if it'is brightness or contrast), disturbing the viewing of the movie.
                                Last year I replaced my screen because got damaged and this contrast/brigthness issue persists. It happens only on the laptop screen, in fact If i plug an external HDMI screen the issue does not occour on it.
                                It occours both on ubuntu and windows...
                                01-01-2023, 05:12 PM
                              • ScHAmPi
                                Samsung UE48JU7000 screen issue after backlight replacement
                                by ScHAmPi
                                Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                07-15-2024, 05:41 AM
                              • smic717394
                                by smic717394
                                07-25-2024, 10:16 AM
