magnavox 37MF321D/37 no power
  • johnboy1313
    • Nov 2012
    • 1959
    Re: magnavox 37MF321D/37 no power
    Every set that I've fixed had that chip go bad. Do a search for IC7003 or LD5973D there is a capacitor that may need to be replaced as well.
      https://www.badcaps.net/forum/showth...ghlight=IC7003
      Read post 23 about bad cap.
      and this one by Johnboy:
      https://www.badcaps.net/forum/showth...light=l5973%2A
      • rsrace
        • Dec 2015
        • 13
        Many thanks Johnboy and BudM. I think I will take a shot at the IC7003 replacement (and the associated capacitor). At the price of the main boards available right now, this seems like the way to go.
        I will also check the outputs of the IC to be sure that nothing is shorted...both boards look like they fried right between pin 7 and 8 as shown in many of those other posts I found in BudM's reply and a search I did of the forum.
        Originally posted by johnboy1313
        Those chips are cheap and easy to replace. Buy two chips and a heat gun. Fix both boards, use one, and sell the other.
        I like the way you think Johnboy - I need to recoup a bit from this ordeal and it would be nice to sell a verified-working main board to help.
        When you say heat gun - do you mean an industrial "hair drier" like is used for shrink wrap and such (I have one)? Is that to release the IC from the circuit board? I assume I do not need to seat the new one with heat as that would likely overheat the IC...?
        I also saw a tip on another post from BudM to cut the legs off the IC first to make removal easier.
        • rsrace
          • Dec 2015
          • 13
          Nailed it! All is working now after replacing IC 7003 and capacitor 2002!
          One of the two main boards I "fixed" did not have any standby after replacing the IC, so I need to go back and figure out what I messed up (because that's a change from low volts). I bought one extra IC and cap from digikey so I might just have to start the soldering over again.
          The other board fired right up and I have picture and power lights again...it has been running for hours now.
          Many thanks BudM and Johnboy1313 ...I could not have done this without you!
          • justice171
            Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
            by justice171
            I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
            Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
            1. Verified that all critical voltages are present:
              • 3.3V and 5V are always present if DC is plugged.
              • 1.8V on the BIOS chip is present.
            2. Checked the power button functionality:
              • When pressed, the voltage drops to 0V, indicating the button is functional.
            3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
              • Confirmed connectivity is intact, ruling out issues
            11-26-2024, 12:39 AM
            03-31-2024, 02:12 PM
          • dragon3x
            >>> Troubleshooting Delta Power MAX 500ATX ATX power supply
            by dragon3x
            Hi, this is for troubleshooting and, hopefully, repairing a Delta Power psu
            that is still quite new, as it worked OK for some months until it failed.
            At the time I was not into power supply electronics; it was put
            aside and a new power supply installed inside the computer. Also at the time
            power supplies were half the price of today's.
            On the PCB there are a D339 and 7500B chips.
            I have found that schematics with these 2 chips (see included file).
            Does it represent the actual circuit of the MAX-500ATX, I cannot tell.
            Some measurements,...
            06-05-2024, 03:34 PM
          • Zippie
            Troubleshooting Old Chiefmax 650Watt ATX Switching Power Supply
            by Zippie
            I’m looking for some advice troubleshooting an old Chiefmax 650w power supply in a PC, if it’s advisable to dig into it.
            Worst case I can replace the PSU, I’m just interested in learning the troubleshooting process. However, it’s out of my area of expertise and I could use some direction.
            During PC operation I heard a loud pop noise, like a cap gun and the tower lost power.
            Initially there is no power output 3.3v, 5v, or 12v when jumping the power on pin to ground. Also, no fan power.
            Opening the PSU the only things visible initially...
            03-07-2024, 07:58 PM
          • ipatch
            troubleshooting microsoft surface pro 4 no power no led charge light
            by ipatch
            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
            10-05-2023, 11:59 AM
