ps50c77hdx/xec
+ More Options
Posts
  • Jimmy1979
    • Apr 2015
    • 120
    • holland
    Re: ps50c77hdx/xec
    Yes ps-on collapse to 0,2v
    • Jimmy1979
      • Apr 2015
      • 120
      • holland
      Re: ps50c77hdx/xec
      • Jimmy1979
        • Apr 2015
        • 120
        • holland
        Re: ps50c77hdx/xec
        Originally posted by ReeceyBurger123
        Ok when it shuts down does Pson collapse ?
        Maybe other idea?
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Re: ps50c77hdx/xec
          You'll need to bulb the psu--see if it will run ok without the set...
          disconnect every plug except mains in from the psu, short ps/on to std 5v and vs on to gnd. Attach 100-150W std lightbulb--not energy-saver--to vs and gnd.
          Apply power to mains input. bulb should light and all other supplies should test as noted on the sockets.
          TELEFIX
          • Jimmy1979
            • Apr 2015
            • 120
            • holland
            Re: ps50c77hdx/xec
            Oke i will try this and see if it runs oke.
            Thanx
            • flocko
              • Nov 2012
              • 1121
              #26
              Re: ps50c77hdx/xec
              Check for 5v stby. then Ps/on should be grounded( made low). this will bring the relays in (all low voltages will now show ) . Vs/on needs a 470-1000 ohm resister jumper between it and 5v stby( made high) to bring the board to life (high voltages Va/Vs will now show if working) test and report
              • Jimmy1979
                • Apr 2015
                • 120
                • holland
                #27
                Re: ps50c77hdx/xec
                ThanxπŸ‘πŸ»
                I have grounded ps/on but the relay doesn't start click voltage 4,0v
                Standby 5v
                I have changed the relay to make sure that isn't the problem but still the same.
                Any idea why?
                • flocko
                  • Nov 2012
                  • 1121
                  #28
                  Re: ps50c77hdx/xec
                  So you have Stby 5v / just the relays not coming in? start checking ICQ805 check the in and out voltages when grounding Ps on .dont forget use hot ground - leg main cap when testing , CQ802/807and 815 can cause this loss as well
                  • Jimmy1979
                    • Apr 2015
                    • 120
                    • holland
                    #29
                    Re: ps50c77hdx/xec
                    Oke i will check this thanx for your help mateπŸ‘πŸ»
                    • Jimmy1979
                      • Apr 2015
                      • 120
                      • holland
                      #30
                      Re: ps50c77hdx/xec
                      I have checked icq805 and voltage in pulsate between 4v and 6v and out 4v.
                      Cq802/807 and 815 i changed them for new caps.
                      • flocko
                        • Nov 2012
                        • 1121
                        #31
                        Re: ps50c77hdx/xec
                        Can you check the 5v Stby when you put Ps on to ground is it still holding 5v?
                        • Jimmy1979
                          • Apr 2015
                          • 120
                          • holland
                          #32
                          Re: ps50c77hdx/xec
                          Yes 5v still there
                          • flocko
                            • Nov 2012
                            • 1121
                            #33
                            Re: ps50c77hdx/xec
                            And ICQ 805 in and out voltage when Ps on is grounded on and off no change, you are using neg leg of main cap (hot ground) as ground for testing ICQ805?
                            • Jimmy1979
                              • Apr 2015
                              • 120
                              • holland
                              #34
                              Re: ps50c77hdx/xec
                              Oke i will check this and let jou know.
                              • Jimmy1979
                                • Apr 2015
                                • 120
                                • holland
                                #35
                                Re: ps50c77hdx/xec
                                When i'm using hot ground and test icq805 with ps-on grounded 0v in and out.
                                And when ps-on not grounded the same.
                                • flocko
                                  • Nov 2012
                                  • 1121
                                  #36
                                  Re: ps50c77hdx/xec
                                  Do you have the schematic for BN44-00161. you can find it at Toms service manuals in the tv repair library. You need to back track from ICQ805 to try and find were your problem is. the viper is working as you would not have 5v stby. start by checking diode DB807 if this is open you would get Ov to ICQ805. if you get the schematic this will help to back track.update and if you get stuck we are here
                                  • Jimmy1979
                                    • Apr 2015
                                    • 120
                                    • holland
                                    #37
                                    Re: ps50c77hdx/xec
                                    Oke thanxπŸ‘πŸ»
                                    • lamouche1
                                      • Feb 2011
                                      • 12
                                      Re: ps50c77hdx/xec
                                      i have nearly the exact problem with a bn44-00162 i have no 15V at icq805 output and nothing at the input i'ved track the voltage down to the qc803 pnp transistor it got around 20v at the emitter coming from the tb801/ viper22 area
                                      the transistor test good the base of the transistor seems to come from pcq802 opto. i'm stuck there for the moment. should i check on the cold side of the opto or stay on hot side?
                                      for the ps_on i'm using a resistor under 1k
                                      i got my 5v standby and it's stable.
                                      i replace the cb816 22uf 450v
                                      checked cq802 cq807 and cq815. the all are ok
                                      all four fets are ok
                                      the guy who gave me the tv set is not sure if the tv quit during a thunder storm
                                        Re: ps50c77hdx/xec
                                        If I remember this BN44-00162A correctly, when PS-ON is LOW, it is = Power supply ON. it is opposite from most other power supplies.
                                        • lamouche1
                                          • Feb 2011
                                          • 12
                                          Re: ps50c77hdx/xec
                                          ps_on is at ground via a 1k resistor
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • Yanleb
                                            Schematic or datasheet for Plasma TV buffer chip
                                            by Yanleb
                                            I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                                            So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                                            Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                                            05-18-2022, 01:36 PM
                                          • legg
                                            LG 42PC3 buffer output doesn't follow YSUS
                                            by legg
                                            LG42PC3D -UD originally with green lamp but no display or audio.
                                            Owner says was working, then went 'pop'.
                                            All 5V caps bulging. replaced.
                                            All PSU output voltages within spec but -Vy is low on YSUS.
                                            One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                            eventually shorts DG. Replaced all 3 - -Vy now OK.
                                            Y scan buffer test point does not follow YSUS output below -50V
                                            Note: This unit seems to expect YSUS output to park at -Vy in between
                                            drive signal pattern periods. A replacement drive signal board confirms this....
                                            11-18-2021, 11:49 AM
                                          • burbutsalos
                                            55" QLED QE55Q60T Turns on after 1 minute the picture goes bad and get in boot loop
                                            by burbutsalos
                                            Hello ,
                                            The issue with this set is that it turn on just fine and after a minute or so the picture shows either vertical lines or turns half black and from that point on starts a boot loop.
                                            If a let the unit to cool down for a minute the same pattern starts again. i had exactly the same mainboard as a spare and replaced it but nothing changed.
                                            Any ideas what to check?...
                                            12-12-2023, 06:06 AM
                                          • shiz1
                                            LG 50PT350 bad lower y buffer
                                            by shiz1
                                            Recently received an older lg plasma for free to fix.
                                            Symptoms - no picture but i have sound. I hear the click of the relay, and the hum from the ysus.
                                            What i've tried - i remove the ysus buffers one by one, when i removed the lower buffer i get picture on the top half of the screen. Removing the top buffer and leaving the bottom still gives me a black screen.
                                            i tested the va/vs at the psu and they're within spec as outlined by the sticker.
                                            I tested the lower buffer checking continuity between the white connector - see attached pics - on the...
                                            01-13-2019, 04:02 PM
