Panasonic TC-P58S2 7 blinks
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P58S2 7 blinks
    nice
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • Biruslapio
      Panasonic P58V11B 8 and 12 blinks error "fix"
      by Biruslapio
      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
      04-13-2021, 07:13 AM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • nobbnobb1
      Panasonic TC-P50U50 Powers Off - 8 blinks
      by nobbnobb1
      I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
      2x DG302 (Q16051)
      2x RF2001 (D16041)
      2x 5.6 ohm SMD resistor
      1x BD8694 IC
      I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
      03-21-2023, 08:33 PM
    • Biruslapio
      Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
      by Biruslapio
      Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
      It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
      It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
      02-16-2021, 09:44 PM
