SAMSUNG UE32EH4003W Restarting
  • sordids999
    • May 2013
    • 2155
    Hi guys
    got this tv today which it keeps restarting voltages on the power supply are good and if i disconnect power to main board the backlights come on and stays on no restarting,so im gathering the main board is faulty and wondering if it might need a eeprom reset ?
    thankyou
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: SAMSUNG UE32EH4003W Restarting
    You can always try and reset the eeprom. Did you check the main board model nr on shop jimmy? Some main boards from samsung have a repair kit that fixes the same symptoms. ( IC on back of the main board ).
    • sordids999
      • May 2013
      • 2155
      how can i perform a reset of the eeprom ? and no i cant find any repair kits
      thanks
      • vinceroger69
        • Mar 2012
        • 6714
        http://wiki.samygo.tv/index.php5/UnB...y_EEPROM_Reset
        • sordids999
          • May 2013
          • 2155
          thanks but i cant find my model number ?
          • sordids999
            • May 2013
            • 2155
            Tried the following:
            Join VCC and SDA, power on TV and hold about for 20 seconds with the TV powered
            but no luck so looks like ill order a main board
            • flocko
              • Nov 2012
              • 1121
              Lee Have you tried pulling the ribbon to the panel to see if its a panel fault, with these sets with no T,Con, any problems with the LCD drivers or tabs you will sometimes see the main board pull down PS on +BL on ? This goes for Samsung and LG sets without T.Cons or built into main board type setups
              • sordids999
                • May 2013
                • 2155
                hi flocko
                yes already tried that but its still restarts the backlights
                • CapLeaker
                  Leaking Member
                  • 8210
                  backlight over current protection firing on?
                  • sordids999
                    • May 2013
                    • 2155
                    I'm not sure all I get is the Samsung logo then nothing else and every twenty seconds the TVs just reboots
                    • flocko
                      • Nov 2012
                      • 1121
                      Had same type of thing with an 3D 47"LG set last week, screen on for few seconds then off and repeat, as luck had it I had a main board out of a 42"and that fitted. That was a non T.Con main board set as well.
                      • sordids999
                        • May 2013
                        • 2155
                        ok m8 ill order a replacement board anyway fingers crossed
                        • sordids999
                          • May 2013
                          • 2155
                          Update:bit late updating
                          mainboard replaced all working again
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            Sweet That model has issues with firmware I did the 40" version and it was the firmware causing it to reboot.
                              09-07-2024, 05:50 AM
                            • JSin21
                              Compatibility of main boards between different variations of samsung MU6100
                              by JSin21
                              Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                              I have Samsung Smart TV UA65MU6100WXXY version DA01
                              Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                              11-27-2023, 04:54 AM
                            • Yanleb
                              Compatibility of Samsung Y Main boards LJ92-01732A no rev vs rev AA2
                              by Yanleb
                              Hi, I did look everywhere to know if Samsung Y Main boards LJ92-01732A without rev marking is compatible with LJ92-01732A rev AA2.
                              If they are not compatible why did Samsung give them the same part number to begin with?
                              08-04-2025, 11:35 PM
                            • elpatxi_bcn
                              Samsung HG75EJ690UB Hotel TV, change main?
                              by elpatxi_bcn
                              Hello!
                              I just got a Samsung TV model HG75EJ690UB 75" and 4K. It is a hotel TV, with a slightly different version of the Tizen operating system than the TVs at home.
                              Being a hotel, it is covered in many functions. With the service menu I can unlock some, but not others. For example, I can't install apps like Netflix etc...
                              The fact is that it seems that I can replace the main by a, say, "normal". I think the one that corresponds is NU7105, ref BN94-02635. At work, which is a convention center and a hotel, I have many TVs from 55" to 85" that...
                              05-19-2023, 03:21 AM
                              09-06-2024, 11:40 PM
