Bushle-46gl12e
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Bushle-46gl12e
    Hi guys just been given one of these 46in full hd sets it uses a megmeet MP4618 psu and a T.SIS231.81 T460H1 P09 L02 VER C1 main the problem you can get it out of standby ok the led flashes blue about 20 times the lcd screen is lit a dullish blue which stays on about 12 seconds all the edge lit leds seem to be lighting looking through the back of the tv metal chassis holes/ no on screen menu volume control source etc seem to do nothing would you guys say faulty eeprom? any tests i can carry out? cheers guys.
    sorry cant spell or edit the title maybe a mod can its a bush le-46gl12e
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Bushle-46gl12e
    Images Vince ?
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Re: Bushle-46gl12e
      Will do tomorrow a little dark here to take good pictures a visual inspection all looks ok i could pull all caps and test esr i guess but i see chs sells a eeprom maybe a common issue i will link pictures of the boards that are the same as mine so you can have a quick look but will upload mine tommorow. ive also noticed whilst the blue standby led is flashing you cant turn the set off on the side switch you have to unplug it.
      http://www.chsinteractive.co.uk/elec...n-le46gl12.htm
      http://www.ebay.co.uk/itm/T-SIS231-8...p2047675.l2557
      http://www.ebay.co.uk/itm/2719135352...%3AMEBIDX%3AIT
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Re: Bushle-46gl12e
        hi guys anyone have a schematic for the megmeet MP4618 psu as if possile i would like to jump the psu to check the voltages are stable this is a good clear picture of the psu as you can see it does not have the voltages printed on it
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8327
          Re: Bushle-46gl12e
          Well... not thaaaat fast... You have STBY voltage. So first check if the main board returns PSon to the power supply. If that main board does not return PSon voltage to the power supply, the TV simply does not turn on.
          You may have a bad main board, let it be an Eeprom problem or the main IC.
          • finntricky
            • Jan 2014
            • 449
            • uk
            Re: Bushle-46gl12e
            i would say eeprom, it wont be the first time i have had the same problems with these sets, technika, jmb, bush, to name a few, but nine times out of ten you cant get the IC for them and have to get another main board,
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              Re: Bushle-46gl12e
              cheers guys i think i will risk ordering a eeprom from chs or ohms supplies they both carry them for this tv so may be a common problem not many main boards for sale with all matching numbers i have searced ebay etc.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                Re: Bushle-46gl12e
                the trouble i have i cant find a psu schematic to find out which is the pson wire etc its like the sets trying to boot for 12 seconds then seems to get stuck and re boots.
                  Re: Bushle-46gl12e
                  The labels for the pins are on the bottom side of the board.
                  MP4618
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    Re: Bushle-46gl12e
                    Thanks budm thats one place i did not look as yet, regarding jumping the psu which pins do i use a 1k resistor across many thanks.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8327
                      Re: Bushle-46gl12e
                      Again, first measure the voltages on those pins, since you have the pin out now and post them here.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        Re: Bushle-46gl12e
                        Hi yes i will measure them asap once my visitors have gone etc as its christmas day here so maybe have to wait untill tomorrow untill i can post all readings.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          Re: Bushle-46gl12e
                          MP4618
                          thanks budm the voltages have just been tested with set in stanby and whilst its trying to boot for 12 seconds with just a dull blue screen no side buttons etc
                          no on screen menu etc
                          please see budms picture for bottom view of board with pinouts i cant add to this post sorry.
                          CNO2
                          PIN 1 NC
                          PIN 2 NC
                          PIN 3 SB 0 VOLTS ON 5.2
                          PIN 4 SB 0 VOLTS ON 5.2
                          PIN 5 SB 0 VOLTS ON 4.5 pson
                          PIN 6 SB 5.2 VOLTS ON 5.2
                          PIN 7 NC
                          PIN 8 NC
                          PIN 9 10 11 EARTHS
                          PIN 12 SB 0 VOLTS ON 12.9
                          PIN 13 SB 0 VOLTS ON 12.9
                          CNO3
                          PIN 1 SB 0 VOLTS ON 23.2
                          PIN 2 SB 0 VOLTS ON 23.2
                          PIN 3 4 EARTHS
                          CN04
                          PIN 1@2 NC
                          PIN 3 SB 0 VOLTS ON 5.1
                          PIN 4 SB 0 VOLTS ON 1.6
                          PIN 5 EARTH
                          PIN 6 NC
                          CN05
                          PIN 1 SB 0 VOLTS ON 93.6
                          PIN 2 SB 0 VOLTS ON 0.04
                          PIN 3 SB O VOLTS ON 0.04
                          CN06
                          PIN 2 SB O VOLTS ON 1.6
                          PIN 3 SB 0 VOLTS ON 1.6
                          So guys whats your thoughts? is it worth trying a eeprom as voltages look ok? as no mains available cheers guys.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            Re: Bushle-46gl12e
                            Guys i have updated the voltage readings whith the correct pinout voltages from the board does this look like eeprom issue? cheers guys.
                            CNO2
                            PIN 1 NC GND
                            PIN 2 NC GND
                            PIN 3 SB 0 VOLTS ON 5.2 + 5 VOLT
                            PIN 4 SB 0 VOLTS ON 5.2 + 5 VOLT
                            PIN 5 SB 0 VOLTS ON 4.5VOLT PSON
                            PIN 6 SB 5.2 VOLTS ON 5.2 5 VOLT VSB
                            PIN 7 NC + 5 VOLT
                            PIN 8 NC + 5 VOLT
                            PIN 9 10 11 EARTHS
                            PIN 12 SB 0 VOLTS ON 12.9 +12 VOLT
                            PIN 13 SB O VOLTS ON 12.9 +12 VOLT
                            CNO3
                            PIN 1 SB 0 VOLTS ON 23.2 +24 VOLTS
                            PIN 2 SB 0 VOLTS ON 23.2 +24 VOLTS
                            PIN 3 4 EARTHS
                            CN04
                            PIN 1@2 NC +12 VOLTS
                            PIN 3 SB 0 VOLTS ON 5.1 BK/ON
                            PIN 4 SB 0 VOLTS ON 1.6 ADJ
                            PIN 5 EARTH
                            PIN 6 NC
                            CN05
                            PIN 1 SB 0 VOLTS ON 93.6 +LED
                            PIN 2 SB 0 VOLTS ON 0.04 -LED
                            PIN 3 SB O VOLTS ON 0.04 -LED
                            CN06
                            PIN 2 SB O VOLTS ON 1.6 -LED
                            PIN 3 SB 0 VOLTS ON 1.6 -LED
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              Re: Bushle-46gl12e
                              Guys any thoughts regarding the voltages ive provided above i cant find a replacement main anywhere but the eeprom is available do you guys think its worth a try?
                              • CapLeaker
                                Leaking Member
                                • Dec 2014
                                • 8327
                                Re: Bushle-46gl12e
                                CN05 and CN6 measure the voltage between + and -.
                                Other than that, it's worth a trying an eeprom.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  Re: Bushle-46gl12e
                                  The voltage between the + and - is 93 volts on both cn05 and cn06 i will try to unsolder the eeprom later as still learning and very small traces (no hot air station) if i can remove ok i will order one
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    Re: Bushle-46gl12e
                                    Just to update this thread i have today ordered a pre programmed eeprom from ohms supplies i will update again once ive fitted it.
                                    • cheeky2
                                      • Dec 2012
                                      • 337
                                      • uk
                                      Re: Bushle-46gl12e
                                      Any news as I have just been given the same model TV with the same issues as yours?
                                      If its the eeprom then it sounds like an easy fix.
                                      I look forward to hearing from you.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        Re: Bushle-46gl12e
                                        Hi sorry only just got around to having a go at the repair yes the eeprom has fixed the issue the set seems fine i will run it later for a few days to confirm its ok.I ordered the eeprom from ohm supplies about £23.00 a word of warning the tracks/pads lift very easy i did lift and break one but managed to solder a small copper wire onto the track and then fitted the eeprom.
                                          Microsoft Surface Redbank i5/8/256 Blue Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Redbank i5/8/256 Blue Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Redbank i5/8/256 Blue boardview and Surface Redbank i5/8/256 Blue schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:50 AM
                                          Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
