Sceptre x322bv-hdr
  • raykia
    • Feb 2014
    • 12
    Sceptre x322bv-hdr
    Sceptre x322bv-HDR as no backlight. Tested with a light shined on screen and can see the volume bar change
    I searched high and low for schematics or service manual with no luck
    Found the output to the led backlight.
    21.34 v is measured out from connector cnb803 to the backlight can someone confirm this the correct reading?
    Measures open on plug to the led backlight.
    I haven't pulled the back to inspect led circuit.
    Before pulling to inspect is it worth it to try to repair the backlight or replace?
    Re: Sceptre x322bv-hdr
    Lets start by uploading the pictures of the whole back side of the TV so we can see how all the boards are connected together, then the close up pictures top and bottom side of the board around the LED connector.
    21.34 VDC is too low, I expect higher than that.
    • raykia
      • Feb 2014
      • 12
      Waiting for a reset for the back of board
      However most likely will not work due to just notice a diode that may be bad
      See the pics
      update: added the back of board plus diode near connector in question reading without pulling from board I should have a reading in the kilo ohms
      8.53 M ohms with diode set reading of .262 V i'll need to at least replace that.
      either way I suspected at least 40 to 60 V for an output to the LED's
      it would be nice to have the schematic and or SM for this
      • raykia
        • Feb 2014
        • 12
        really not much to this unit in way of components
        • spirittoo
          Sceptre 48" TV backlight LED`s
          by spirittoo
          Trying to fix a backlight problem with a Sceptre 48" TV.
          I found replacement strips with the same part number as the strips in the Sceptre, but the new backlight strips have 5 leds per strip and the ones in the tv has 6.
          So I decided to replace the leds instead. I found 3 bad ones. I had no problem removing the bad ones with a heat gun, they came right out. However the leds on the replacement strip would not come out with heat. I use my solder iron as well, they will not come off.
          Anyone know how I can remove those leds without damaging them?
          11-11-2023, 10:23 AM
        • DanPoka
          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
          by DanPoka
          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
          02-15-2025, 05:05 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
        • cheebster
          iPad Pro 12.9 5th Gen Backlight Issue
          by cheebster
          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
          Anyone...
          05-20-2025, 09:17 AM
        • canadaboy25
          LG Flatron 24EN33TA No Backlight When Cold
          by canadaboy25
          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
          03-07-2023, 12:23 AM
