LG 32LV3400zg starts fews minutes later
  • fpsousa
    • Dec 2015
    • 29
    • Portugal
    I have a TV led LG that sometimes, starts and all is running ok and sometimes, don´t start immediately; sometimes (not always the same), could be 5 sec or 10 minutes later, it starts.
    Measures: PSU - 3.5 V ST-BY is always ok but misses RL_ON from the uP. When it turns on, the 12V a 24V are ok too, so the PSU seems to be ok.
    On main board I've checked that 24 Mhz crystal is ok, and uP generate POWER ON/OFF but RL_ON don´t.
    On panel Led indicator is blue (on).
    If the TV remain connect with mains 220V and Red led is light, the Tv starts but if disconnected from mains the malfunction appears.
    I have schematic.
  • chaos-theory
    Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
    by chaos-theory
    I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
    Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
    03-14-2025, 05:37 PM
  • arabex21
    Asus Prime B450M-A starts only when 12v 8pin cpu plug disconnected
    by arabex21
    Hello everyone. I have been reading this forum for a long time - I really appreciate the amount of very interesting materials and information in the field of electronics.
    I have a problem with this configuration:
    ASUS PRIME B450M-A
    RYZEN 1300X (I replaced it with ATHLON 200GE - the same behavior, the processors are functional, tested on another board)
    When the entire set is installed (CPU, RAM, ATX connector and 12V 8 pin CPU plug), the board starts up for a while (about 1-2 seconds), the CPU fan starts and the board turns off immediately. When I disconnect...
    09-19-2024, 03:05 AM
  • waigy
    HDD stops after about 2 minutes
    by waigy
    Seagate barracuda compute 6TB 3.5 inch drive.
    When I power on my pc, at 1 minute 20 seconds I am into windows and I can see and access this drive.
    But only for 20 seconds then it will freeze and disappear from my system.
    So it won't be in device manager or computer management/storage.
    I've tried lots of different hard drive software that runs from a usb boot stick and the same happens there.
    The drive is only available for less than 2 minutes then it's gone.
    Same in the bios, it shows when first opening the bios, but if I exit the bios then go...
    10-26-2023, 08:38 PM
  • aaronkatrini
    DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
    by aaronkatrini
    I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
    - Put the card in my testing motherboard and start running Heaven benchmark
    - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
    - Try to start it again and I get a slight move from the PSU fan - a clear short
    - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
    - Put the...
    05-18-2025, 04:18 PM
  • sofles
    Macbook Pro 16" A2141 screen artefacts, kernel panic
    by sofles
    Hi there.
    I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
    I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
    Now situation looks like this, If...
    02-05-2025, 05:05 AM
