got this set when I power on backlight will come on then after a few sec. backlight shuts off but power is still on. I have all proper voltages but the last 24v where is says pwr on is only 3.5 so im not sure if its suppose to be 24 or not?
Help lg 47lw5600 backlight going out
Tags: None
Re: Help lg 47lw5600 backlight going out
Please upload the pictures of the whole back side of the TVto show all the board and pictures of the whole power supply board top and bottom side.Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
'pwr on is only 3.5; That is the same as PS-ON, it is the control signal form the main board to turn on the rest of the power supplies, so 3.5VDC on the PWR-ON is correct.
P201 is 24 pins connector.Never stop learning
Is this your power supply-LED driver board?
http://www.shopjimmy.com/lg-eay62169...upply-unit.htm
LG EAY62169801 (EAX62865401/8) Power Supply 47LV5500 47LV5400 42LW5300
16 LED strings!Last edited by budm; 12-17-2015, 12:43 PM.Never stop learning
yes and I just checked 1 of the pins going to the leds, starts up at 65v drops down to 35 when shuts offComment
So the LED + pins of LED connectors P202, P203 show same reading of 65V?
It sounds like it goes into protection shutdown.Never stop learning
bud all the + start at 65v when the backlight is on then after 3 secs the backlight shuts off and the + will all read 35vComment
OK, using Chassis as the GND ref for the meter.
Take the DCV reading of all LED strings GND return, there are 16 GND returns, they are test points EL62~EL77, you will have red probe connected to those test points start with EL62, you will have the cycle the TV ON 16 times, we need to find out if one of the string has open circuit or not so correct measurement is very important.Never stop learning
They all go up to 10v when there on then once backlight goes off they go down
el62-el77
1.8
1.8
6.2
7.8
4.7
3.1
3.5
4.9
5.2
4.7
6.2
4.9
3.9
2.0
2.6
2.3Comment
I have not had many led sets come in my shop. Where the backlight flash with bad led. Usually the bad led I have had come in usually screen does not light up at all. But all other voltages are present so I guess it would have to be leds?Comment
I also wanna thank you. You and tom have been the lifesavers of this forum. Without you two I dont know how else would be here.Comment
The one that does not come on at all are the one that has all the LEDs connected in series like a Christmas light, one goes open circuit then the whole string will not light up, this one has 16 LED strings and one circuit for each string, so if one string goes out the other will still light up but the protection circuit will kick in.Never stop learning
Is there anyway to bypass the protection circuit and make it run like it is now? Cause when picture comes up it looks fine. Not lighter anyewherw on pictureComment
There are two SMD ICs on the bottom side of the board close to those test points, I believe they are for the LED driver circuits. You will have to get the spec sheet to find out how it works and how the protection circuit functions.
By the way, is there a cable between T-CON and the power supply board?
Can we see the pictures of the whole back side of the TV?Never stop learning
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Comp_ProHello all,
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... -
by canadaboy25Hi all,
I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...-
- Loading...
