samsung ln46a540p2fxza red light blinking
    Re: samsung ln46a540p2fxza red light blinking
    http://www.shopjimmy.com/samsung-bn9...repair-kit.htm
    Replacing just C102 (Tantalum 47uF 10VDC) will usually solve the problem.
    From SJ PAGE:
    The Samsung BN94-02077D Main Board Component Repair Kit includes all necessary components to repair common failures on the Main Board. Symptoms include no audio on any input, repeatedly turns on and off, red power LED blinks forever.
    Samsung BN94-02077D (BN41-00975B, BN97-02472D) Main Board
    • cjrolke
      • Dec 2015
      • 21
      • usa
      Yes I was using chassis ground
      • cjrolke
        • Dec 2015
        • 21
        • usa
        I do not see a c102
          The 'C102' silkscreen printing is partially under the IC IC101. it is on the right of R107.
          https://www.badcaps.net/forum/attach...8&d=1450311523
          Notes: Silver bar on this TANTALUM cap indicates POSITIVE leg of the cap.
          • cjrolke
            • Dec 2015
            • 21
            • usa
            Ok I guess I need to order one of those capacitors
            • cjrolke
              • Dec 2015
              • 21
              • usa
              #26
              What is the difference between a black and beige capacitor? Looking on ebay currently. Unless you have a better suggestion. Thanks
                http://www.digikey.com/product-detai...0CT-ND/4146673
                • cjrolke
                  • Dec 2015
                  • 21
                  • usa
                  #28
                  ok just ordered one
                  lets see if it fixes the issue
                  thanks
                  • cjrolke
                    • Dec 2015
                    • 21
                    • usa
                    #29
                    You are good. I replaced that capacitor. C102 and the tv is working now
                    Thank you very much
                      Thanks for the repair follow-up.
                      • cjrolke
                        • Dec 2015
                        • 21
                        • usa
                        #31
                        I appreciate the help
                        • jet
                          • Apr 2012
                          • 58
                          I attempted this fix, got the cap replaced but in the process I lost R107, my eyes are not what they used to be and soldering with a magnifying glass is tough LOL. Can someone tell me the value of R107 so I can replace it?
                          TIA, jet
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #33
                            ive looked at a few pictures online r107 it looks like 180 is printed on it? maybe budm has a idea or a picture showing the resistor as im sure he has done this repair before
                            • jet
                              • Apr 2012
                              • 58
                              so if it is 180 that make is 18 ohms then i think?
                                R107 is 18C = 15K Ohms (http://www.talkingelectronics.com/pr...-Markings.html)
                                R104:39K (R1 formula), R107:15K (R2 formula) are the Vout Voltage setting resistor network, in this case, it is set to 3.3V Output for the IC101 MP2363.
                                • jet
                                  • Apr 2012
                                  • 58
                                  budm,
                                  Thanks for that chart I did not have that, have saved it to my bookmarks. I will get on it in the morning, will also check R104 to make sure it's OK.
                                  Now back to watching The Tragically Hip's last show OTA on my 50" Samsung Plasma I repaired with help from this forum
                                  Thanks again will let you all know how it worked out
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #37
                                    Thanks budm thats a better picture than i managed to find and thanks for the resistor smd chart ive saved it too.
                                    • jet
                                      • Apr 2012
                                      • 58
                                      Got it going (no power cycling) now I have to fix the bad picture. I think I saw another thread here somewhere on that. Looking now.
                                      • Barn01
                                        • Jun 2015
                                        • 16
                                        I've got the blinking red LED as well. I've replaced the usual caps on the P/S and that didn't change anything. They didn't look bad but I thought it was a go to. Then I found this thread and started playing with the main board.
                                        I've replaced C102 on the back and C131 on the front with 47uF Tantalum caps but not surface mount. See pics!
                                        Anyhow that didn't fix it.
                                        I also re-soldered the legs of IC101 and that didn't fix it either.
                                        Any thoughts?
                                        • matty24
                                          Samsung UE50MU6172 - red light blinking
                                          by matty24
                                          Hello. I have problem with Samsung UE50MU6172.
                                          TV won't turn on, red standby light is blinking.
                                          Power supply BN44-00807A is fine. I replaced it with the new one.​
                                          Main board BN41-02568B (BN94-12530E)
                                          I've read a dump (W25Q40CL). Can someone check it od fix it for me?...
                                          03-02-2025, 08:57 AM
                                        • Fergal22
                                          Samsung UE40F5300AK blinking red light
                                          by Fergal22
                                          I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
                                          When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
                                          I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
                                          Any help would be appreciated...
                                          02-02-2023, 09:19 AM
                                        • norbiszoke
                                          Samsung 50AU7172, only blinking red light
                                          by norbiszoke
                                          We have this set here in our shop that is not ginving sign of life besides red light that is blinking one time after pressing the button and nothing more... After detaching the mainboard from the PSU (this set has separate board thank god?! or not...) the backlight comes on. After reattaching nothing besides red light.... Can anyone from the forum help me here? Thank you in advance. Here's a link with images of the mainboard and the memory IC's that are on it.
                                          Regards, Norbert!...
                                          04-17-2024, 06:54 AM
                                          09-07-2024, 05:50 AM
                                        • 3DDD
                                          Samsung UE46D6100 LED TV blinking red light indicator
                                          by 3DDD
                                          Hello, I have a Samsung UE46D6100. It cannot be turned on, only the red status LED flashes, the power supply part bn44-00458a gives an output of 5V(A), it is probably functional. I don't know where to look for the error, according to the video it should be a faulty mosfet. I found a mosfet marked WAAH, I don't know what it is. Can anyone help me?...
                                          02-20-2025, 12:51 PM
