Samsung PS51E55D1M
  • Geoff.
    • Apr 2015
    • 20
    Samsung PS51E55D1M
    Hoping someone can help. I have the Samsung PS51E55D1M and a couple of nights ago the thing went pop. Since then there is no picture. I can power it up and there appears to be power to the screen but no picture. switching between different inputs makes no difference.
    Please help.
    Geoff
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung PS51E55D1M
    Pictures?
    • Geoff.
      • Apr 2015
      • 20
      hi Hamie,
      Are you wanting pictures of the PCB's?
      • Hamie
        • Apr 2014
        • 1383
        Yes
        • Geoff.
          • Apr 2015
          • 20
          Hi Hamie,
          Please see below.
          • Hamie
            • Apr 2014
            • 1383
            Ok so on the control board.
            This one:
            Does the LED blink once every second or once every six seconds?
            • Geoff.
              • Apr 2015
              • 20
              its on for 6 secs off for 2 secs then repeats
              • Hamie
                • Apr 2014
                • 1383
                Ok you see these silver test points marked VS and VA
                Use your meter on DC volts.
                Black probe to the TV chassis.
                Red prob to either of the test points.
                Post results
                VS=
                VA=
                Also there should be a similar point on the Y-sustain called VSC (VSCAN)
                Post its result.
                VSC=
                • Geoff.
                  • Apr 2015
                  • 20
                  This is on the PSU board, correct?
                  Post results
                  VS=
                  VA=
                  I have an SVC VS and an SVC DGND, is this what we're looking for?
                  Post its result.
                  VSC=
                  Is the above correct Hamie
                  • Hamie
                    • Apr 2014
                    • 1383
                    Vs va points above.
                    Yes also post the result of service vs on the y-sustain.
                    But you need to find the point called VSC or might be labelled as VSCAN.
                    • Hamie
                      • Apr 2014
                      • 1383
                      Take a good photo of the y-sustain face on, not at an angle.
                      • Hamie
                        • Apr 2014
                        • 1383
                        The test point for VSC might be a jumper wire.
                        It will be labelled, And should be close to a potentiometer also labeled VSC.
                        • Geoff.
                          • Apr 2015
                          • 20
                          Post results
                          VS= 10.7VDC
                          VA= 0.2VDC
                          Post its result.
                          10.7VDC
                          VSC=
                          Please see above
                          • Geoff.
                            • Apr 2015
                            • 20
                            The VScan has 0.0VDC
                            • Geoff.
                              • Apr 2015
                              • 20
                              Apologies Hamie, The power keeps turning off VSCAN is at 2.9VDC
                              • Geoff.
                                • Apr 2015
                                • 20
                                VSCAN back to 0.0VDC now
                                • Alastair E
                                  Chief Womble
                                  • Mar 2013
                                  • 1963
                                  • U.K.
                                  Hmm--Went Pop...
                                  No Vs, PSU shutting down, falling Va.
                                  Short on Vs line--prolly on Y-SUS.
                                  Check for shorts on Vs Line and the IGBT's/MOSFETS on both Y-SUS and X-SUS.
                                  If Y-SUS short, Check Buffers too. Buffers Kill Samsung Y-SUS when they fail.
                                  TELEFIX
                                  • Geoff.
                                    • Apr 2015
                                    • 20
                                    Thanks Alastair,
                                    If there is a short on the Y-SUS is it possible to fix or do i replace the board. having read the link, How can i check the buffers?
                                    • Hamie
                                      • Apr 2014
                                      • 1383
                                      Pull the y-sustain from the tv and take a photo of the underside of the board.
                                      • Geoff.
                                        • Apr 2015
                                        • 20
                                        Thanks Hamie, will do tonight.
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • Dodgethis
                                          Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                          by Dodgethis
                                          Hello all,
                                          This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                          09-11-2024, 07:39 AM
                                        • YellowJacket
                                          Samsung QE55Q60RAT - no picture
                                          by YellowJacket
                                          Hi friends,
                                          a friend of mine gave me this TV to fix, with common SAMSUNG TV issue - damaged panel. Turning on, sound is present, but no picture. So I went directly to standard process, connecting two pads together with a wire ( see in the picture ), and then removing flex cables. With right flex connected, there was half screen working, but still no picture ( disappearing colors and similar weird stuff ) + working sound. With left flex connected, TV is restarting + working sound. I supposed, left side is damaged, so I then blocked all 8 CLK pins ( going from 0R resistors on the second...
                                          07-30-2024, 01:31 PM
