Sanyo DP52449
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: Sanyo DP52449
    The top R/H connector, below the right hand side of it. The small white rectangular ceramic device.
    • joeshannallie
      • Dec 2013
      • 103
      • usa
      Re: Sanyo DP52449
      Thanks for the reply. Are you meaning the one I have circled in red?
      • cliff_hootarski
        • Jul 2006
        • 411
        Re: Sanyo DP52449
        yes.
        • joeshannallie
          • Dec 2013
          • 103
          • usa
          Re: Sanyo DP52449
          Thank you. I have one more question, How would I know if the actual panel is bad?
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Re: Sanyo DP52449
            Its on the left hand side, just above the ldvs connector marked F1.
            White in color.
            • cliff_hootarski
              • Jul 2006
              • 411
              Re: Sanyo DP52449
              TV off, preferably unplugged. disconnect either the left or right pair of connectors that go from the Tcon board to the LCD Panel. Turn on the TV, note the picture.
              Turn off the TV, wait a couple of minutes, reconnect the two cables, disconnect the other two, note any change in the picture and report the results.
              (Preferably with pictures).
              • joeshannallie
                • Dec 2013
                • 103
                • usa
                #27
                Re: Sanyo DP52449
                Thanks! I will do that but it will be later this evening.
                • jasonbay13
                  • Jul 2014
                  • 185
                  • usa
                  #28
                  Re: Sanyo DP52449
                  i think its that little white thing just below the top right connector, marked F1.
                  since you've ordered 2 boards, its either wrong board or not the problem.
                  also, i still have the other 2 boards if you have the same tv i could send them over to you. whats the sticker on the main board say?
                  • cnti
                    Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
                    by cnti
                    Hi.
                    BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
                    This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
                    BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
                    RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
                    burned, measured 10M ohm.
                    QM801 [real PSU:...
                    10-19-2023, 05:33 PM
                  • cj_reha
                    Mystery 80s Sanyo cap - perhaps polymer?
                    by cj_reha
                    Hey all I've been working on a 1984 Sanyo 27" color TV which had a smattering of bad caps in the video switching circuit. I found this oddball little 1uF 25V cap which looks to me like an early polymer, but I can't find concrete info proving it. I know Sanyo was a big player in early polymer cap development and this is the time period where they were just getting on the market, so I'm wondering if anyone has crusty old datasheets that could help identify it and determine if my suspicions are right? It has the same epoxy end seal and font/formatting as some old stock Os-Cons I've got laying...
                    01-06-2023, 09:24 AM
                  • edugimeno
                    Diagnose real-vintage Strong-Hammer arcade machine
                    by edugimeno
                    Hi there!
                    My friend wants me to help him repair his old-real-vintage strong-hammer machine. Well it's only 90% real as the force applied doesn't lift the weight itself but it is measured and it moves a motor that lifts the weight
                    I am attaching several pictures of the machine.
                    It basically has 2 sides, left side has
                    • 2 x 220->12+24v transformers
                    • 2 relays (1 moves motor UP, other moves motor DOWN)
                    • IGF and breakers for safety
                    Right side is shown on pictures. It has 3 boards ( top-down)
                    • Logic board. Receives 24AC and recitifies it into DC. Contains a uC (M80C85)
                    02-29-2024, 11:05 AM
                  • DynaxSC
                    by DynaxSC
                    11-17-2023, 10:56 AM
                  • toddw65
                    Sanyo DP5834 - Gray Screen
                    by toddw65
                    Hey All,
                    I have a Sanyo DP5834 that did have an issue with the backlights, but I disassembled the unit and repaired the LED strips by resoldering all of the connectors. Now I've reassembled it and I have backlights and sound, but a grayish screen. I can tap on the screen and see that it's on, but no picture. All voltages seem to be correct on the power board.
                    Based on the LCD Flat panel TV troubleshooting guide by Bud Martin, I'm thinking the T-Con has failed because I'm getting 12v both into and out of FP1 on the T-Con. Am I on the right track?
                    Thanks,...
                    10-31-2024, 10:37 AM
