Hey all, I have a 37" set that will not turn on. When the power switch is pressed, the power board has a bit of a buzz (need to go someplace quieter or I need better ears to figure out which specific componnent is making the noise) but no backlight, video, or sound comes up.
Measurements I've already taken: (DC values across cap legs and secondary side voltages from chassis ground)
- 114 vac into power board.
before pressing power button:
- 160 vdc on each of the large primary side caps (C800A/B)
- primary side C907 comes up to about 22-24 vdc when plugging in set then settles at 14vdc a few seconds later
- secondary side pair of caps C950A/B each read 5.22 vdc
- 12 pin connecter to main (CN202) has 5.1 vdc on pins 1-3
- pin 11 reads 0 until power button is pressed then reads 3.2vdc until the power button pressed again and drops back to 0
- the other pins all read 0, even after pressing power button. There are a couple of grounds that I obviously expect to read 0vdc but the 12vdc pins to the main board and the DIM & BL_ON signals never change
-whlie the 3.2 vdc is applied to power board, the big pair of primary side caps reads 395 DC each.
-I got 0 vdc acoss secondary side caps C700A and C704 regardless of power on signal applied to power board.
Looks like I have STBY power and power on signal back to power board from main board when button is pressed but then the 12VDC to main board never comes up and the LEDs never turn on either. I just finished reading one of the threads about VIZIO voltage regulators so i found some other post about how they work and how to measure them. I'm going to go back, look up datasheets and take some more values across any voltage regulators I can find.
I'll get back with more readings but if anyone has any other suggestions or wants to look at something specific, please let me know what else to check next. I did throw a picture of the main board in as well but I really don't think I have any issues there and I need to learn how to take pictures under better lighting or something to get rid of the glare.
Thanks!
Thanks!
