samsung ps42q97hdx, strange problem
  • finntricky
    • Jan 2014
    • 449
    • uk
    this tv i got showing a strange problem, where you turn the tv off and after half an hour or so the screen will light up, and then go dim, there will be no display, just a glow from the screen, it will stay like that all the time untill you turn it back on, then the screen goes black/turns off, then comes back on as normal,as if you was turning on to watch tv, anyone got any ideas.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: samsung ps42q97hdx, strange problem
    Checked for cold solder joints on the Psu ?
    • finntricky
      • Jan 2014
      • 449
      • uk
      all ready did m8, and done a few dodgy bits, someone already been at it and made a bad job, burnt off some solder points, so had to repair them, non soldered caps, lol, but prob still there.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok do you have a hair drier ? Try heating the boards to see if it speeds up the failure mode.
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • mmccomputer
          problem with replacing lcd screen
          by mmccomputer
          I have an HP model : 14-cf0011nf and I want to change its display screen (it has an original 14" full HD TN 30 pins panel) which works without problem but I want to put another screen with an IPS panel, the problem is that I tried several screens but there is no display except with the original screen, I never had this problem before I changed hundreds without problems but this PC is not 'accepted than its original screen
          otherwise on the motherboard it displays edp and I don't know, do the panels I tried only work with the LVDS protocol?
          If anyone has any information on the subject...
          12-15-2024, 03:44 PM
        • Chrissygizmo
          samsung galaxy ao2s very temperamental after screen replaced
          by Chrissygizmo
          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
          Ive eventually managed to get it on and working but it's very temperamental...
          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
          05-26-2024, 12:05 AM
        • jimjoe123
          LCD TV Green/Pink screen problem
          by jimjoe123
          I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
          Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
          Then each time...
          02-23-2020, 01:29 AM
        • CityZen
          Samsung un48ju6700 half screen ghosting problem
          by CityZen
          This curved LCD TV has an issue affecting just the right side of the screen. It is not a backlight issue, although it might appear so from one of the attached images. The problem appears to be the right side of the screen not updating properly. Moving images on the very right side will leave a trail of ghost images. Although even just the computer cursor sitting still makes a vertical ghost band the entire height of the image. The color on the right side also looks like it doesn't have the full bit depth (the Windows background looked kind of dithered on that side).
          I went into...
          11-24-2021, 12:03 AM
