Samsung LE40B620R3W no back light
  • 24mech
    Badcaps Baby
    • Feb 2014
    • 103
    • United Kingdom
    Good morning Badcaps, is everyone ready for the silly season lol.
    I'm hoping for some advice please, I have an LE40B620R3W when the unit powers up you get all the right chimes and the screen shows the channel for a brief second then the screen goes black I have used the light trick and can see that video is there just no back light, the sound is ok no issues there. I have had the back pannel of and taken the power/inverter board BN44-00264A out it looks like someone has had a go at repairing this previously.
    Thats the history so my questions are:-
    1. Does the fact that the screenlights up briefly when started point to a board problem or is it more likly to be a back light issue.
    2. If its a board issue and the fact its already been repaired would I be better of replacing the board?
    3. Is there a way to confirm board or backlight before going any further.
    Thanks in advance for your help
  • Hamie
    • Apr 2014
    • 1383
    Re: Samsung LE40B620R3W no back light
    Does the mainboard still send the BL-ON signal when the backlights cut out?
    • Hamie
      • Apr 2014
      • 1383
      Btw on this power supply you don't need to 'jump it on'
      If you disconnect the mainboard from the power supply and plug it in.
      The backlights will come on, and should stay on until you unplug it.
      • 24mech
        Badcaps Baby
        • Feb 2014
        • 103
        • United Kingdom
        Thanks for your reply, I will try this when I get back later this afternoon and report back the results. I take it if the lights come on it will be a board issue I'll take some pictures of the board as well to get peoples thoughts on repair v's replace Thanks for the response Hamie
        • 24mech
          Badcaps Baby
          • Feb 2014
          • 103
          • United Kingdom
          Hi there again people, I took some pictures of the board, I disconected the main board from the av so it only had the 240v power plug conected and powered it up, no back light did I do this correctly or? also it looks like several items have been replaced on this board already, what do you think?
            What is the P/N of the power supply/inverter board combo? BN44-?????
            • johnboy1313
              • Nov 2012
              • 1959
              Bud, that's a BN44-00264A.
              24mech, follow the instructions in this thread to pull up the service menu to get to the test patterns. With a fully white screen, you should be able to see which bulbs aren't firing. Then, test that transformer against the others to see if it measures bad. I haven't seen a lot of bad transformers on the 00264A board. The 00264B board is a different story. My guess is that you have at least one bad bulb.
              https://www.badcaps.net/forum/showthread.php?t=29580
              • 24mech
                Badcaps Baby
                • Feb 2014
                • 103
                • United Kingdom
                Good morning once again thanks, johnboy1313 I have read the thread you linked to my back light does not come with the 30p disconected, are you surgesting I bridge out CI805 or CI806 to get the back light to come on?
                • 24mech
                  Badcaps Baby
                  • Feb 2014
                  • 103
                  • United Kingdom
                  Ok so I bridged out CI806 and we now have a back light it looks like the upper bulb isn't working and after being on for just a little while it started to smell hot, looking closer the inverter transformer for that bulb TI801S was a lot hotter than the other 3 is it worth my time swapping this with one of the others to see if the fault moves?
                  • 24mech
                    Badcaps Baby
                    • Feb 2014
                    • 103
                    • United Kingdom
                    I've swapped TI801S with TI803S and rebuilt the unit (trying to identify bulb or board issue). I have carried out the master test and these are the results (CI806 is still bridged out) I noticed that none of the transformers are notably hotter can someone point me in a direction to go next as it looks liike swapping the transformers has helped but I'm not sure what to do next.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      I would test the primaries and secondaries of each transformer and compare the readings against each other. If one transformer is noticeably different than the rest, I'd suspect a bad transformer. Personally, I still suspect bad bulbs.
                      If the one transformer isn't getting hot anymore, maybe you had a bad solder joint that you corrected by swapping the transformers. Have you tried to remove the bridge at CI806?
                      • 24mech
                        Badcaps Baby
                        • Feb 2014
                        • 103
                        • United Kingdom
                        I've removed the bridge and the problem came back, if its a bulb how can I test it? are they easy to replace?
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          Replacing them involves opening the panel. It's not difficult but it could lead to a damaged screen if you're not careful, which would basically make the TV a box of parts. You'll have to strip the panel to the metal box, leaving the power supply connected. Then remove the metal frame around it by removing several screws and carefully lifting the frame. I wear rubber gloves to remove the screen and lay it on a blanket on a flat surface up away from any kids or pets. The black plastic under the edges of the screen (you'll see it when you get there) will probably have a few screws holding it together as well but it might just snap together. Once that's removed, you can pull the diffuser layers. Keep these together and do not mix up the order. They need to be put back in the same order as they came out. At this point you'll see the bulbs. I use pieces of wood to keep the panel lifted off of the table enough so the power supply isn't supporting the weight of the panel. I suppose you could use a sturdy art easel too. That way you'd have access to both sides of the panel as you work. Plug the set in and observe which bulbs don't fire. Make sure your solder bridge is still there. I can't remember if the bulbs are soldered in or if they are clipped in. Either way, it isn't difficult to swap them out. I found a 40" Sony with a cracked screen to scavenge bulbs from locally on Craigslist. Another guy on here bought six bulbs for 5 pounds at a TV repair shop in his neighborhood.
                          The main points are just be careful and put everything back together the same way it came apart.
                          Go for it.
                          • 24mech
                            Badcaps Baby
                            • Feb 2014
                            • 103
                            • United Kingdom
                            Well I've got it this far (though I wasn't the first to do so the seals were already cut) and it looks like 1 dead one and a few on there way, how do I test the bulbs?
                              You have lots of bad/worn lamps with blackened ends and those ends got hot to discolor the white plastic shield.
                              Also remove that white plastic shield to see if they also have ballast caps.
                              • 24mech
                                Badcaps Baby
                                • Feb 2014
                                • 103
                                • United Kingdom
                                Hi there I have removed the plastic's and the bulbs at the inverter end look corroded? do I need to replace them all and where can I get thwm from, I've looked on ebay without success :-(
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  I was in a very similar predicament with my set as well. You're likely gonna want to replace all 14 bulbs or face digging into it again in the near future. Just to be sure, I would swap the dead bulb with a working one to see if the dead bulb stays dead in a new location. That will rule out the transformer for sure.
                                    You need to clean all the lamp sockets and replace ALL the lamps if it is worth it for 40" TV, they probably had set the backlights level at full blast.
                                    • 24mech
                                      Badcaps Baby
                                      • Feb 2014
                                      • 103
                                      • United Kingdom
                                      Ok where can I get bulbs from and whats the cost likly to be does anybody know?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        you would need to measure the diameter of the tube and the lengh of them first
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                          09-07-2024, 05:50 AM
                                        • Chillin014
                                          No back light on Samsung UN65MU6290, Need help modifying Power Supply Board.
                                          by Chillin014
                                          Hello all and thanks in advance for helping me with this.
                                          I am a novice TV repair hobbyist and just picked up this Samsung UN65MU6290 / PS board # BN44-00873C with no backlight but otherwise seemingly fully functional. My initial assumption was the LED strips were bad but upon further research apparently the Power Supply board can also be at fault for "over driving" the LED strips. On ShopJimmy they are recommending to replace some resistors and other components (transistors?) in conjunction with the LED strips (although their referenced Youtube link only demonstrates replacing...
                                          08-20-2020, 08:28 AM
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
