TV acting strange after cleaning screen
  • tech2014
    • Aug 2014
    • 807
    I have a customer who is having an issue with a smartTV. His wife sprayed the screen with mr clean and now its acting weird. When he is using his remote to change from the on screen options, it seems to have a mind of its own. It will move on its own between icons on screen, or when he moves it left, it moves to the right. Any idea what could be causing this? It worked fine before cleaning so I assume its a screen issue.
  • Hamie
    • Apr 2014
    • 1383
    Re: TV acting strange after cleaning screen
    more than likely she's used a cloth charged with static and damaged the touch sensitive buttons.
    • tech2014
      • Aug 2014
      • 807
      thanks. Is this something that is repairable or not?
      • Hamie
        • Apr 2014
        • 1383
        Diagnose it first.
        Unplug the buttons from the main board.
        Use the remote and see if it still changes icons etc.
        If not then you know it's the buttons.
        Good chance someone will be selling them.
        Alternatively use your ohm meter and check for differences in resistance.
        Or of course, just tell the customer to use the remote and leave the buttons disconnected.
        • tech2014
          • Aug 2014
          • 807
          bu buttons I assume you mean the power/input/menu buttons on the bottom/side of the tv.
          • Hamie
            • Apr 2014
            • 1383
            Yes
            • tech2014
              • Aug 2014
              • 807
              will the remote work without the buttons/sensor being connected to the main board?
              • Hamie
                • Apr 2014
                • 1383
                well if the remote sensor isnt plugged into the mainboard its not going to work.
                there will be a way to diconnect the buttons.. even if it involves removing the wires from the harness.
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Or if the buttons are on the bottom, she sprayed to much on the screen and this has run down between the frame and is making sporadic connections.
                    • 31298
                    this.
                    i'v seen all kinds of damage from people spraying cleaner on the screen including rusty frames!
                    • tech2014
                      • Aug 2014
                      • 807
                      thanks guys.
                        It is also bad if it uses one of those screen where the tab bonding boards are at the bottom side in stead of on the top side of the screen, they get corroded and ruin the screen, seen that many times.
                        • tech2014
                          • Aug 2014
                          • 807
                          I hope thats not the problem budm. Thanks for the input guys.
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
                          • jkruns
                            M1 A2338 screen and touchbar issues after cleaning up liquid damage
                            by jkruns
                            This is my first post after browsing this wonderful treasure trove of knowledge for many, many evenings. I've decided to learn how to fix these things, properly.
                            My patient is an A2338 Macbook Pro M1 (late 2020).
                            It had some corrosion around JT710 and JT700 caused by liquid spill, as well as against the protective barrier around the USB-C chips UF000 and UF100. So I took the main board out and cleaned it with a toothbrush and alcohol, then with alcohol in an ultrasonic cleaner. Cleaned the touchbar flex connectors as well. The board looks...
                            04-22-2024, 06:45 AM
                          • reformatt
                            by reformatt
                            07-31-2025, 08:37 PM
                          • smic717394
                            by smic717394
                            07-25-2024, 10:16 AM
                          • Chrissygizmo
                            by Chrissygizmo
                            02-10-2025, 12:33 AM
