Re: HISENSE F42K20E LED Tv - No backlight
I have no idea. You may want to look up the spec sheet of the LED driver UC701 to see if they have any explanation on how it works.
Yes I wish I knew the specs of it.
I was playing with color options/brightness etc and with the random inductor I have in currently, there was no change to brightness or anything. Most likely bc the LEDs are being overpowered.
Would that be a result of a lower inductance or higher? As the voltage to the LEDs is 15v more than its supposed to beLeave a comment:
You need to get the right inductance, current rating, dc resistance.Leave a comment:
Could I use anything else that'd be similar?Leave a comment:
FERRITE pot, i have no idea where to get the replacement, the print on top looks like LEI-302B.Leave a comment:
I can't see the windings they're incased. Did you see the picture of it I provided in an earlier post?Leave a comment:
Ot sounds like the sub is not the right one to use.
Can you look at the old inductor to see if the open circuit can be fixed.Leave a comment:
132v on c848 and 260v to led pin 1+ which is over what the board has labeled at 245v
Is this due to the random inductor I soldered in for L702?
Backlights work still but L702 gets pretty hot to the touchLeave a comment:
What DCV do you have on C848 (Input Voltage to boost converter)?
The Cathode of the LED string should be connected to the Drain pin of the PWM Controlled MOSFET U703, the Source will be connected to the current sensing resistor, and another end of the resistor is connected to GND return. The Vdrops on the current sensing resistor is used for feedback to maintain constant current.
If you look up the spec sheet of IC U701 LED driver IC it may have example circuits on how it is used.
BTW, I think the MOSFET designators are 'V'xxx, and ICs are 'U'xxx.Last edited by budm; 12-22-2015, 12:56 PM.Leave a comment:
Removed L702 and it tests open. Problem is I can't find anything online using the part numbers. Ended up soldering in a .02mH inductor from a scrap board and backlights came on. Reads 134v to 1+ of led connector.
Is it safe continuing to use this inductor? It's smaller, most likely the original was a higher value
What I'm wondering is if L702 is part of a boost converter, wouldn't the 134v fed into it be stepped up rather than maintaining that voltage to the LEDs?Last edited by caphair; 12-22-2015, 09:28 AM.Leave a comment:
So would L702 be bad preventing the 134v from being boosted closer to 300v to power the LEDs?
Is U701 the only mosfet being used to boost the voltage to the LEDs? I'm confused about u703's role in the circuitLast edited by caphair; 12-22-2015, 06:14 AM.Leave a comment:
So the mosfets are getting a signal from the ic driver as my meter showed a frequency of 200-240hz on the gates.
There's 134v coming off the secondary side of the transformer that feeds the drain of u701 mosfet, however I noticed one side of L702 has 134v but the other side that connects directly to u701 only has 1v
The resistance of L702 is 5mega ohms. Is that the culprit?
L702 should show <10 Ohms.Leave a comment:
The resistance of L702 is 5mega ohms. Is that the culprit?Leave a comment:
I must have misdiagnosed originally, when I probe + of the 10uf 350v capacitor connected to 1+ terminal of led strip it measures in millivolts and slowly climbs to 1v then drops.
Here are some pics of backside of the board, some connections looked questionable so the flux residue is from my resoldering some points.Leave a comment:
Ok finally had a chance to rip the panel apart and I tested each led using 3v battery. Every one lit up, now I'm stumped.
Also checked wiring going to the strips using continuity checker and they checked out. So it's the power supply?Leave a comment:
You can use 5 Diodes (1N4007) in series to simulate 1 White LED, or use 3.3V 1W Zener connected in reverse bias. Edge lit LED is harder to replace the LEDs.
using diodes
https://www.badcaps.net/forum/showpo...&postcount=181Last edited by budm; 12-01-2015, 11:18 AM.Leave a comment:
Would it cause any problems if I shorted the bad one/s if it's a constant current circuit? Could I use a regular diode in place or another component? Assuming I couldn't find replacement LEDs for it.
This is the meter I have:
http://www.amazon.com/AideTek-VC97-M.../dp/B008GTEZPILeave a comment:
What range did you put the meter in when you are not using the Auto range? Make and model?Leave a comment:
by frannyjunkSo I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
TIA. -
by ojmcBackground:
- Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
- I replaced all 6 of the backlight LED strips with these replacements: amazon
- The TV worked again perfectly for ~2 weeks.
- After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
I joined hoping I'll be able to verify which component I need to replace on my Hisense 60R6E. When I plug it in the red light comes on and stays on for several seconds then blinks off and then on again. There is no back light but I can see the logo screen "Hisense Roku" (using the flashlight method) come on while the red light is off. Then it dissapears and the red light is constant again. This cycle keeps repeating. I tried pressing the reset button and it has absolutely no impact. Even held it in for 30 seconds also tried holding the power button in with the TV unplugged - nothing...
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
- Loading...
