Magnavox 32ME303V/F7
  • alja
    DIY Junky
    • Aug 2013
    • 47
    Hello, here again kindly asking for help to fix this tv
    Model: 32ME303V/F7
    Brand : Magnavox
    Problem: Steady Stand by light. No sound, no picture.
    Pictures as follow from the back of the TV.
    Thanks in advance for the help. It's been quite a long time since I don't dive into electronics but last TV I was guided on was a Success so I'm fast learning and follow directions accordingly
  • CapLeaker
    Leaking Member
    • 8146
    Re: Magnavox 32ME303V/F7
    sounds like the main board isn't turning on the PSU. Check the PSon.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Do you have a DMM and know how to check for S/C aka short circuit ?
      • alja
        DIY Junky
        • Aug 2013
        • 47
        I do have a digital multi meter but I'm not sure how to look for the S/C
        • alja
          DIY Junky
          • Aug 2013
          • 47
          I've tried to test the diodes on the power supply board but I'm not sure if they are right. A site that I looked on said that the diodes should give me a reading only one way and the other way should be OL so some of them were giving me readings both ways .... that means those are bad? how could I know the correct reading I should get from the diodes. I don't really know what I am looking for but it's a start.
          This power supply is totally different from the ones I've seen before because I cannot find voltages to measure ... so I don't even know if is the main or the power supply that is bad or both.
          any help is well appreciated.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            What Ohmage do they give ? Sorry for slow response btw.
            • CapLeaker
              Leaking Member
              • 8146
              So 5V comes from the PSU to the main board. If you press the "On" button, the mainboard returns the PSon signal to the PSU to turn on all power rails. The TV comes on. If that mainboard doesn't send PSon to the PSU, it won't come on. Easy check.
              • alja
                DIY Junky
                • Aug 2013
                • 47
                The ones on top of the transformer from left to right are the ones that don't give me OL
                0,28 - 2.8
                the ones at the bottom right of the transformer give me
                OL - 2,4
                OL - 2
                OL - 2,5
                OL - 1,9
                • alja
                  DIY Junky
                  • Aug 2013
                  • 47
                  Well that is exactly my problem that I cannot find where to measure those 5V
                  • CapLeaker
                    Leaking Member
                    • 8146
                    Everything connected, turn the PSU around so you have access to the back side. Put black probe to GND on the secondary and measure all pins on that ribbon cable that go between PSU and main board. Check each pin and press that power button on the TV on and off. Note everything down. Be careful not to short a pin with a different one with the probe. Also it may not be 5V either.
                    • ron350
                      • Feb 2014
                      • 296
                      Alja i don’t think you have to unbolt the power supply just read all of the jumper labels.
                      • alja
                        DIY Junky
                        • Aug 2013
                        • 47
                        Thank you CapLeaker, I did what you instructed me and here the values
                        The power button seems to do nothing, the values don't change when I press the button.
                        from bottom to top there are 11 pairs and measured
                        00.0 - 00.0
                        00.6 - 03.3
                        00.0 - 03.3
                        00.0 - 03.3
                        00.0 - 00.0
                        00.0 - 00.0
                        00.0 - 00.0
                        12.9 - 12.9
                        12.9 - 12.9
                        00.0 - 21.0
                        21.0 - 21.0
                        • alja
                          DIY Junky
                          • Aug 2013
                          • 47
                          ron350 I tried but I don't really know what to look for, I measure the ones that says 21v and 3.3 but don't know what else to do.
                          I forgot to mention that the big capacitor of 330 uF reads 297 uF .... I guess this is not ok? but would it be the culprit?
                            What DCV do you on those jumpers, they are labeled with DCV?
                            P-ON +21V=
                            ALL 3.3V =
                            BL-SW =
                            PROTECT3 =
                            AMP+13V =
                            ADIM P =
                            Pictures provided by shopjimmy.
                            http://www.shopjimmy.com/emerson-a3a...pply-unit.htm#
                            • alja
                              DIY Junky
                              • Aug 2013
                              • 47
                              Thanks Budm. here the values
                              P-ON +21V= -0
                              ALL 3.3V = 3.3
                              BL-SW = 0
                              PROTECT3 = 0.6
                              AMP+13V = 13
                              ADIM P = -0
                                P-ON +21V= -0
                                ALL 3.3V = 3.3
                                BL-SW = 0
                                PROTECT3 = 0.6
                                AMP+13V = 13
                                ADIM P = -0
                                The power supply is an always on power supply with one transformer to supply all the needed Voltages.
                                The P-ON +21V is generated by Diode D650, D651 (they are connected in parallel).
                                The AMP +13V is generated by Diode D653, D655 (they are connected in parallel). The +13V is down converted to +3.3V, 13V is also used for the audio amplifiers.
                                You must have measurement error because you do have 13V, so the +21V has to be there also (not likely that BOTH Diodes have gone bad) because it is coming from the same power transformer for the +13V, so recheck that +21V again. The +21V is used for running the LED Boosted Voltage LED driver.
                                The main board is not sending the BL-SW (BL-ON) either.
                                • alja
                                  DIY Junky
                                  • Aug 2013
                                  • 47
                                  I've checked all the labels and the values are accordingly where says 13v there is 12.98 where says 21v is 21v but only the one you pointed out to me to check, the one next to the connector to the logic board that says "P ON +21v" (J180) is not showing me the 21v the rest of the 21v labels read indeed 21v. I also found the 3.3v where it should be.
                                  Also there is a humming comming from the transformer everytime I energize the board.
                                  And before the tv died it was hard to turn it on but eventually it would until no more.
                                  • alja
                                    DIY Junky
                                    • Aug 2013
                                    • 47
                                    I don't really know what this means....
                                    • CapLeaker
                                      Leaking Member
                                      • 8146
                                      Means that the backlight behind the LCD screen isn't turned on either. So your screen stays black. That alone tells me that you have a main board problem, as this signal is also generated there like the PSon.
                                      PSon = Power Supply On
                                      BLon = Back Light On
                                        So the power supplies are OK then since you do have all the Voltages, but missing the BL-ON signal. You should monitor the BL-ON signal to see if it even change state at all when you turn on the TV.
                                        • tonybig10
                                          Magnavox MDR515H/F7 And Magnavox MDR537H/F7
                                          by tonybig10
                                          Hi is any one can help me on getting the Schematics for Magnavox MDR515H/F7 And Magnavox MDR537H/F7 PDF file thank you I really appreciate it. Just need to change some component on
                                          the main board and the power supply board. I looked all over for the internet and I cannot find the Schematics sheet for both of them. I don't know where else to look I hope someone can help me...
                                          03-07-2025, 01:03 PM
                                        • DAVEMAC02
                                          Inverting op amp follow up
                                          by DAVEMAC02
                                          Follow up to my op amp diagram of Q208 FET and IC204 for NJM 2068M op amp. I took took the following DCV readings on the Q208 (2SK246) and IC204 pins:
                                          pin 1 0v, pin 2, 0v, pin 3 0v, pin 4 -15.6v, pin 5 0v, pin 6 .08, pin 7 0v, pin 8 +15.9v
                                          Q208 source -.006, gate -15.5v, drain -.102. These readings are from the op amp Q208 that has no output on pin 1. I don't know what state ie (On or Off ) Q208 should be when op amp is working correctly. This circuit is on the filter/limiter stage of the PA system. Any help is appreciated. Thanks
                                          10-03-2024, 01:08 PM
                                        • sudz28
                                          Magnavox 27MS5402/17 CRT - no picture, flashing green light
                                          by sudz28
                                          I'm going to assume my beloved Magnavox CRT is toast, but also figured maybe this was a good opportunity to dip my toes into he circuitry waters and maybe learn something new. Also, I don't want to trash it if it's a fairly cheap/easy fix!
                                          My 20-year-old Magnavox has gotten me and my kids through many a gaming console change and worked great up until the other day. Following a long distance move, it sat in our garage for a year and now that I brought it in and turned it on I get no picture; instead, a green light blinks on the front of it; 7 flashes, one long flash, then 3 more...
                                          02-08-2022, 10:09 AM
                                        • barrybahr
                                          Magnavox 32MD350B/F7 getting a false on/off control voltage
                                          by barrybahr
                                          The unit is stuck in an intermittent on/off cycle. When I plug in the power cord, the green "On" light activates without any command, flashes for a few seconds, then turns off. The red standby light comes on for a few seconds before the cycle repeats. During this time, I cannot turn off the unit manually; it will shut off automatically after about five minutes, and there is no picture. Occasionally, with repeated attempts to power it on, I eventually get a picture and sound, which function properly. When it does work, I measure several voltages, and they appear to be normal....
                                          04-20-2025, 10:30 PM
                                        • legg
                                          LG 42PC3 buffer output doesn't follow YSUS
                                          by legg
                                          LG42PC3D -UD originally with green lamp but no display or audio.
                                          Owner says was working, then went 'pop'.
                                          All 5V caps bulging. replaced.
                                          All PSU output voltages within spec but -Vy is low on YSUS.
                                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                                          Y scan buffer test point does not follow YSUS output below -50V
                                          Note: This unit seems to expect YSUS output to park at -Vy in between
                                          drive signal pattern periods. A replacement drive signal board confirms this....
                                          11-18-2021, 11:49 AM
