Sharp Aquos lc-70le857u 70" TV display problem
  • ajshoe
    ajshoe
    • Dec 2012
    • 477
    • usa
    Re: Sharp Aquos lc-70le857u 70" TV display problem
    When u have the set on with the good picture - I then install the last connector very carefully. u can then have the whole set on - should be strobing !! might take u several times to get it right. then u know it can be fixed.
    • egreene15
      • Nov 2015
      • 16
      Here are the pictures of the one cable disconnected, when i disconnect the other side by itself I get no difference in my display from my original problem. I am not at all sure what the issue is or how to go forward from here, thanks for any help!
      • budwich
        • Jul 2015
        • 3097
        yep that's the "classic tab issue"... the dark side is the side with the bad tab somewhere. Carefully remove the bezel and INSPECT the edge boards and tabs along that side by "carefully" releasing the boards from the frame clips so that you can see both sides of the boards AND the tabs. You will likely see a discolored tab and / or tab driver depending on how bad things are. You might also feel a temp difference on that side with all cables attached as the bad driver(s) will be hotter than other normally operating ones.
        Glad you got this far... probably could have got there sooner but the "journey" is always a winding one AND never the same.
        • ajshoe
          ajshoe
          • Dec 2012
          • 477
          • usa
          would suggest u make up a table with 2x4s to set tv on. top 2x4s are smaller than tv so it holds screen safely. I would not remove entire bezel but just the 3 sides to allow enough of bezel to be lifted up to work on the "bad" side. GOOD LUCK.
          • freakaftr8
            • Oct 2012
            • 3743
            True. It seems that this occurrence is becoming more and more common lately. You most likely have a faulty driver. This would require you to remove the tab drivers and boards on that non functioning side of the panel unfortunately.
            Here's the video I made as a tutorial. I know it's a Sony in the video but same beast of a panel both manufactured by Sharp.
            This should give you an idea of what is involved
            https://youtu.be/A9UaWnsF2Mg
            • egreene15
              • Nov 2015
              • 16
              Can i replace the drivers or is my only way out of this by pulling the side tab drivers off like in the video? Did you ever get rid of that dark spot on yours after taking your drivers off on that one side?
              • egreene15
                • Nov 2015
                • 16
                When i plug the bad cable back in with the tv on, the screen turns off and i get the flashing 2-5 code, when i unplug it and turn tv back off it goes back to the one half good screen. Thoughts?
                • egreene15
                  • Nov 2015
                  • 16
                  Well I found the bad driver, looks burned out, pictures below. first picture is of the bad burned one, second picture is of one of the good ones (to show the difference). From what I've read and watched I am to carefully pull all these out from the screen? I want confirmation before I do something irreversible! Thanks everyone!
                  • egreene15
                    • Nov 2015
                    • 16
                    Well I got antsy and after a lot of reading I was confident I had to peel off the tab drivers so I did and...it worked! I realize it is prone to complete failure once the left side drivers get burnt out/die but for a free tv i can't complain! Thanks everyone for your help in getting me to this point! Let me know if anyone has any questions to help further understand this repeating problem that Sharp is know known for! Thanks!
                    • budwich
                      • Jul 2015
                      • 3097
                      now that wasn't hard.... :-) glad you got something out of it.
                      • freakaftr8
                        • Oct 2012
                        • 3743
                        Yes it slowly went away. Is probably memory resident in the panel from the short it take some time to alleviate but good job on your Repair.
                        • ajshoe
                          ajshoe
                          • Dec 2012
                          • 477
                          • usa
                          #32
                          How is everyone's sharp aquos 70 working out ?? Mine is still working very well - small line (about 5 inches) I had on top left side has gone away. This set has turned out to be a very good "find".
                          • zep123
                            • Apr 2020
                            • canada
                            #33
                            hi , so my 8 years old LC70LE857U is acting like your tv
                            since I am not a T.V guy , do I try to save it?
                            I just ordered a new 70 inch 4K from LG
                            the sharp was great , but only 7-8 years
                            never used the 3D
                              • 12206
                              • U.S.
                              #34
                              Try powering up one side of the screen at a time by disconnecting each ribbon cable, one at a time and see what you get on display.(always disconnect and reconnect cables with power cord unplugged to avoid any damage)
                              • scubacamper
                                Sharp Aquos LC-70C6400U Half Screen Dark
                                by scubacamper
                                I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                05-03-2025, 12:19 PM
                              • sefoster
                                Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                by sefoster
                                I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                11-20-2022, 09:29 AM
                              • Yehuda170
                                ThinkPad P15s Gen 1, NM-C931 REV 1.0 touch screen replaced only works in UEFI menu
                                by Yehuda170
                                original screen was BOE NV156FHM-T07 with On-Cell Touch screen I²C
                                replaced with what was in my stock, which is IVO R156NWF7 R2 which is also with On-Cell Touch screen I²C
                                now touch screen works perfectly in UEFI BIOS menu & boot menu. but not working in OS, tried windows & linux too
                                with original broken screen i can see in device manager touch screen in human interfaces
                                but with the new screen it's not showing in device manager
                                is it lenovo blocking it? is it driver missing?
                                I²C is a headache
                                07-14-2023, 01:29 AM
                              • thesharpfella
                                Is this white-washed screen caused by a faulty T-Con board or panel? Sharp Aquos c70le735x
                                by thesharpfella
                                Hello esteemed gentlemen. I have owned this LCD TV since 2012. The only repair was the replacement of the PSU a few years ago. Apart from that, no issues. Recently, all was working fine until I switched on to see it appear as so. The day before it was working fine. There is sound. Could this be a T-Con board issue? If not, what could it be? Thank you.
                                07-23-2024, 10:37 AM
                              • EazyBone
                                Sharp LC-65Q620U White Screen
                                by EazyBone
                                Another TV topic!!
                                I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                08-21-2024, 12:56 PM
