samsung pn58a550s1fxza tv turns on with horizontal lines then shuts off
  • Garrettgomez55
    • Nov 2015
    • Usa
    I Have a samsung pn58a550s1fxza 58 inch plasma I'm trying to fix. The tv comes on then shows horizontal pink and red lines then shuts off. It repeats that turns on and off by its self. Also the whole screen isn't lit up with lines just the bottom half the rest is black. I did some research on it and things were pointing to the y Substain board. So I replaced the board but still having the same problem. I noticed on the logic board the led lights on it is blinking like crazy. So I not sure if it's that or something wrong with the main board. Any advice would be great!
    Re: samsung pn58a550s1fxza tv turns on with horizontal lines then shuts off
    Pictures of the main board, probably bad C102 SMD cap.
    http://www.shopjimmy.com/samsung-bn9...550s1fxza.htm#
    https://www.badcaps.net/forum/showpo...&postcount=129
    • aaronwt6
      • Apr 2013
      • 855
      • US
      Agreed with budm. The lines are going to be the main board. I'd replace both C102 and C131. I offer repair service on these on Ebay if you need a hand. And then the screen issue sounds separate. Most likely an upper Y-Buffer board since the bottom 1/2 lights up ok.
      • freakaftr8
        • Oct 2012
        • 3743
        Could be a shorted buffer board causing the lines.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Ihandyrepair
          Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
          by Ihandyrepair
          Hi guys
          I just started fixing 4k TV few months ago. so I am still learning a lot
          I got this tv from friend complaint is ghosting or horizontal lines on image.
          never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
          then it started to show the ghosting white image.
          I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
          it has 3 thin small boards at the bottom of the...
          12-05-2022, 04:18 PM
        • ggil44
          Sony XBR-65X750D Horizontal lines bottom of screen
          by ggil44
          Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
          05-30-2023, 07:51 PM
        • noisykid
          Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
          by noisykid
          5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
          12-30-2024, 07:15 PM
        • x_orange90_x
          Samsung UN46C8000XFXZA Horizontal lines
          by x_orange90_x
          I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
          I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
          07-15-2023, 05:06 AM
