No picture 42PC3
  • paulstef
    • Dec 2013
    • 724
    No picture 42PC3
    is there any manual (training or similar) that gives more information than the useless service manual??
    The hybrid module on the Z-sustain was defective, repaired it. Still no picture.
    VS and VA are ok and get to the Y sustain board. The hybrid module on the Y board seems to be ok, no direct shorts are measurable.
    There was one FET shorted, replaced it, nothing changes, it doesn't blow again either. There is humming noise coming from the board... Don't really know how to proceed.
  • TVRepairNoobie
    • Feb 2015
    • 158
    Re: No picture 42PC3
    PDF file is too large to upload, sorry.
    • paulstef
      • Dec 2013
      • 724
      Originally posted by TVRepairNoobie
      Hth
      • TVRepairNoobie
        • Feb 2015
        • 158
        http://www.toms-service-manuals.com/...&Search=Submit
        • paulstef
          • Dec 2013
          • 724
          This is the service manual, There are next to no informations about the sustain boards. I'd need a training manual maybe (or even better a schematic)
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Going to sound dumb have you replaced or checked the fuses on Y and Z ?
            • paulstef
              • Dec 2013
              • 724
              That's a good link, thanks, unfortunately the problem is not on the power supply...
              • paulstef
                • Dec 2013
                • 724
                One fuse on the Z was open, all other fuses were ok. Z is repaired.
                I can't see any other defective semiconductors on the Y.
                I don't know what is supposed to be coming out exactly from the Y board to the buffers :-/ I have a scope to measure.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  So did you replace the fuse lol ?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Also does the Zsus make a buzz noise.
                    • paulstef
                      • Dec 2013
                      • 724
                      You know the answer :-D
                      Yes, everything makes nice buzzing noises, only I have no picture. I would need to know what to measure on the output of the Y-sustain...
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        I asked because some one here before found a blown fuse then not fucking replaced it hahaha Anyway does the screen glow in a dark room ?
                        • paulstef
                          • Dec 2013
                          • 724
                          Haha, too funny.
                          No, there is no glow coming from the screen, it's completely off. The blown FET on the Y sustain makes me think there might be something else on this board....
                            If there is no -Vy and Vsc you will not get a glow, so check if these are present. Can be shorted Y-buffer, which will cause no glow.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Also you replaced the IPM on the Z sustain did you check the fusible resistors that are located below that IPM.? I believe they're labeled 101 and they're black rectangular shape.
                              However you should still have a picture with a zsus completely disconnected will this be very dim in this proportion and kind of like tearing paper
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Not true Ive had a failed Zsus with blown fuse and Ipm, Vs & Va all good cause no image at all.
                                • paulstef
                                  • Dec 2013
                                  • 724
                                  I will check the proposed items in the evening, thanks.
                                  • freakaftr8
                                    • Oct 2012
                                    • 3743
                                    Now that I think about it you're probably right I'm thinking about the PC50 1to5d 50 inch model I believe that one will show a picture with no z
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Now that I think about it you're probably right I'm thinking about the PC50 1to5d 50 inch model I believe that one will show a picture with nosey says
                                      • paulstef
                                        • Dec 2013
                                        • 724
                                        I get VSC constant 110VDC and -VY goes on and off all the time 0V/5V. Like half a second on then off and so on. There seems to be a problem with this voltage.
                                        Is it save to disconnect the Y-buffer from the Y sustain and turn the TV on?
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • H34TO
                                          ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                          by H34TO
                                          Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                          06-17-2025, 07:17 AM
                                        • ermals
                                          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
                                          by ermals
                                          Hi all!
                                          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
                                          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
                                          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
                                          3. I've checked voltages...
                                          08-01-2022, 10:35 AM
