Apex LE3224 Screen discoloration.
  • isfoster89
    Noob
    • Dec 2013
    • 8
    I have an Apex 32" Led with some odd screen discoloration. It's cloudy in a way and darkens the screen in the affected area. The darker areas also are prone to ghosting. Any help on a fix or where to start? Thank you very much in advance.
    Found this puppy in a place I'm moving into and was left by a previous occupant. I'm hoping to get lucky.
    Not much help but good for a few laughs now and again.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
  • Chrissygizmo
    by Chrissygizmo
    02-10-2025, 12:33 AM
  • spice_disc
    Vizio TV M50-C1 reboot cycle and static on screen
    by spice_disc
    I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
    The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
    09-08-2024, 02:37 PM
