Proscan 50" PLDED5066A-E no backlights
    Re: Proscan 50" PLDED5066A-E no backlights
    It's possibly a led fault. Turn the backlight down (not brightness) say to 60% and see if they stay on longer which they usually do when there's a led problem.
      OK so you do have a LED backlight problem. Do as dick barton suggests and see if it will remain on longeror not shut off at all. If that works it still would not last too long and you would have to crack the panel open and replace those LED strips. If you figure out which LEDs are faulty DO NOT jump them wit wire as the rest of the strip will demand more current from the Driver and eventually burn out. In my experience the best repair is to change out all the strips with new ones as the older ones will fail in time and you will have to open her up again.
        All the backlights light up so why would you say its a backlight problem? I just thought something other was shutting the light down. Could I check the leads to the lights with a multi meter and what shoud the readings be.
          I tried to turn the backlights down but the tv does not have a backlight setting.
            what is your contrast setting? what is your brightness setting? what is your dynamic contrast setting?
            you might have to get into the service menu to "attack" the backlight setting.
              I was thinking that testing the backlight tester with a MM or LED tester does not supply the full current and that when they are in the circuit getting full current they trip out. We have seen this before.
                you could also be looking at a connection issue in between the led strips. as they warm up, they are loosing connection somewhere. either way, you will need to look inside.
                WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                  https://www.badcaps.net/forum/attach...2&d=1448078807
                  Try turning down the Brightness, this set may use the Brightness setting to also controlling the Backlights level.
                  You can take the reading at the 'ADJ pin and see if that Voltage will go down when Brightness is turned down or not.
                    This may be available from the service menu.
                      Thank you Guys for your help.
                      I just ordered a Output Multipurpose Smart LED Lamp LCD TV Backlight Tester so I might be a little while before I get back at the tv. It seems to be a backlight problem so i'm stuck without a backlight tester.
