Re: Proscan 50" PLDED5066A-E no backlights
Ic1f
I would get the P/N of that IC1F and then find the spec sheet so you can at least find out if it has DCV at the VCC pin of the IC.
The BL-ON signal should activate that IC so it drives the GATE Isolation transformer to dive those two power MOSFET for transformer for the LED power supply.
It is probably PWM IC.Last edited by budm; 11-22-2015, 11:04 PM.Leave a comment:
Where should I start trying to trace it out. Thank you for helpingLeave a comment:
It is good. This is not going to be easy without the diagram at this point to find out how that power section works. IC1F SMD IC on the bottom side looks to be the one that does the job.Last edited by budm; 11-22-2015, 10:30 PM.Leave a comment:
Out of curcuit read 22.31 nfLeave a comment:
I think the LED power supply is not being turned on.
Transformer T1F is the Gate drive isolation transformer that drives the Q1F, Q2F which I do not think it is driving right now.
You can also check the rectangular cap C10F (transformer coupling/DC blocking cap for T2F to see if its capacitance is correct.Last edited by budm; 11-22-2015, 08:37 PM.Leave a comment:
.661 V between legs of c8f and the same .661 V of c9fLeave a comment:
OK, so we do have Voltage for the LED driver circuit, the MOSFET Q 1F, Q2F are for driving the power transformer T2F which is for providing the Voltage for the LED driver circuit.
What DCV do you have between the two legs of the brown cap C8F, and between the two legs of brown cap C9F?Leave a comment:
I'm sorry I guess I posted it incorrect it is 384 v. Sorry for confusing you.Leave a comment:
L2 is the PFC inductor, the PFC and L2 are OK otherwise you will not have the 384V DC on the cap.
https://www.badcaps.net/forum/attach...0&d=1448075181
In the picture you show 173VDC on C13, you had indicated you were using the negative leg of the as the GND ref for the meter in post 1., but now you have 384VDC.Last edited by budm; 11-22-2015, 06:49 PM.Leave a comment:
384.0 V. It appears I loose the voltage on L2Leave a comment:
So verify the DCV again by measuring between the two legs of the main filter cap when TV is powered on to see what you have.Leave a comment:
the 400V main filter cap (that looooong skinny cap). Just be careful not to short or touch anything on the primary.Leave a comment:
Any suggestions where or how to look for it?Leave a comment:
You do have PS-0N but you do not have PFC boosted Voltage to run the LED driver circuit, you must get the Boosted Voltage first.Leave a comment:
Take the transformer out and check it. Maybe it is open (thermal fuse inside the transformer)?Leave a comment:
by max789Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
I made the following tests:
1. Disconnected the main board from Power Board = backlight works.
2. Connected the main board and disconnected the T-Con = backlights does not work.
So I ordered a main board from Ebay also BN41-02156A but from... -
by bpcannan'Morning,
I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate... -
by htv239Hello,
I am currently troubleshooting an LG 60UH8500 TV (2016 TV). Any help or suggestions would be appreciated.
Overall Issue: When TV is turned on, backlights all come on for about 10 seconds, then all go out. There is sound and there is a picture on the display (obviously hard to see without backlights, but it is there).
What I Have Done So Far: 1) Removed the back TV cover to expose the boards (Power Supply, Tcon, and Main), 2) blew out any dust and cleaned all connections, 3) Noticed that the LED backlights are fed from two separate connectors... -
by Francesc V.Hi:
i am trying to repair this Christmas lights from my parents. They are incandescent lights, no led lights.
I have tried with 12V a 24V small lights that I found in Aliexpress but is obvious that are not the right ones. They last microseconds connected. Do they blow because of Amps or Volts?
If I measure the Amps in the string........it's only 90mA. If I measure the Volts in the "green box"......it's between 0 and 190V, but doing a little bit of maths from the number of bulbs in series.......it's only about 6V per lamp.
Could... -
by jesteraceHi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
However, I am in a dilemma.
I tested the backlight outputs with the lights disconnected... - Loading...
