Problem with Samsung LCD LN46A500
  • Doug13
    • Nov 2015
    Having an issue with my 6yo Samsung LN46A500. A while back, picture went primarily green/pink. Initial research suggested cleaning ribbon cable connectors which I tried without success. That suggested the T-CON board wax faulty. I ordered a new board and installed. No success at first until I accidentally stumbled across changing a setting labelled "LVDS OUT format" to "PDP". That fixed the picture back to flawless image. Thought my problem was solved but...
    ...after about 5-10 minutes, the screen goes white with black horizontal and red vertical lines. No idea what the problem is now. Anyone see this before and/or have any thoughts on what the problem might be...and the fix?
    Doug
    09-07-2024, 05:50 AM
  • howardc64
    Samsung UN55JU650DF network/streaming problem
    by howardc64
    Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
    This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
    07-09-2025, 12:44 PM
    09-06-2024, 11:40 PM
    09-06-2024, 08:40 PM
