Hi
Resistor replacement which one needed?
by jinu_j
by TomyleeHi everyone,
Sorry for the person who’s going to read all this !
I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the... -
by RyanRizDear All,
I need assistance creating clearMe bios. The laptop is shorted PCH, after PCH replacement laptop can ON but cannot boot. Power supply current reading is 2.5-3.0 Amp.
Model : G512LW-WS74
SN : LCNRKD009429512
CN : ANE9
Attach backup bios.
Thanks for your help.
Best Regards....-
Channel: BIOS Requests ONLY!
by maedayWhile removing the glue, I tore off one resistor, marked in the photo. If anyone can, please measure it and tell me its value.
Regards.
...12-19-2024, 12:23 AM -
by mikey5791Hi to all forum members,
Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor... - Loading...
