LG 32LG3000 problem
  • Iersuo
    • Oct 2015
    • 31
    • Ulu
    LG 32LG3000 problem
    Hello! Got an LG LCD TV which has a following problem:
    Half the time TV works correctly, then suddenly the picture will become all broken and might freeze and become cracked. Below some examples of the image. Then when the TV is touched a little the picture will jump around and after some tinkering a position where the image becomes normal again, can be found. After that the process repeats irregularly. Anyone has a suggestion where to look for? I suspected loose contacts, tried re-seating - no effect. Now I suspect the soldering, but as I am not experienced with electronics I want to know what boards should I look for, to not take everything apart. Z-sus? Y-sus? Something else? Thanks in advance
    Images:
  • Iersuo
    • Oct 2015
    • 31
    • Ulu
    Re: LG 32LG3000 problem
    If more info is needed, tell me
    • Iersuo
      • Oct 2015
      • 31
      • Ulu
      No ideas anyone?
      • diif
        • Feb 2014
        • 6978
        • England
        Not YSUS or ZSUS, they are only in plasma TVs. Did you check the cable to the tcon ?
        • Gootch46
          • Oct 2015
          • 57
          Im guessing Bad Panel, I had a tv ghosting like this once and it was bad news at the outcome, when it does this try grabbing 2 nopposite corners and give it a little twist see if it fixes itself or changes , if so Im thinking panel.. good luck
          • Iersuo
            • Oct 2015
            • 31
            • Ulu
            Found the problem after disassembling the whole TV into parts. The issue is in the ribbon cable on the board in the upper section of the LCD where the T-CON gets connected to. Seems like it has been damaged somehow, although visually everything seems ok. What helped was that I put some cotton between the board and the cable to stretch the cable a bit. TV works as following now: Turns up only on a the second try, but after that everything works correctly and moving the TV does not create any problems. Anyone has a suggestion on how this can be fixed correctly? Seems like the cable is not made to be changed, so I am guessing the LCD has to be changed, which is of course not viable as the TV costs itself less than the LCD panel. Anyways would like to hear some suggestions.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              The solution for this problem is to re-glue the lcd connection. Im not sure if this works with just home material.........
              Most people fix this issue as you fixxed it. They dont use cotton though. I fixed some tv's with carbon and electrical tape.
              https://www.youtube.com/watch?v=mMo3NBGLwH0
              Video is made by Tom66.
              • Iersuo
                • Oct 2015
                • 31
                • Ulu
                Got it, I"ll replace the cotton with electrical tape, otherwise I guess I leave it like that, re-glueing must be done by the factory, I bet it is barely possible to be done at home. Thanks for the info though!
                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:20 PM
                • vabea
                  Asus X550LD Image problem
                  by vabea
                  Hello i have this notebook Asus X550ld they work normal but the image appears with interference (like video attach) i have try, New lcd and a new cable, but unsuccessful if i connect to a external monitor the imagem in the external monitor is normal without interference, any help?
                  Thanks...
                  04-07-2025, 08:33 AM
                • Jaime Morillo
                  Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                  by Jaime Morillo
                  Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                  The TV was stuck on the logo and I couldn't access the update menu.
                  I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                  The image result was good, but the image is inverted.
                  The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                  Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                  08-18-2025, 11:38 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                  HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                  This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                  09-06-2024, 10:56 AM
