'Samsung factory reset' not working
  • UKsparks
    • Nov 2015
    • 5
    • England
    "Samsung :- Mute. 182. power. (tv is off)"
    ___________________________________
    Have tried the above advice from this forum but it doesn't work, it just switches the TV back on.
    Model : LE37R88BD
    Any other suggestions as to how to access Factory Reset ?
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: 'Samsung factory reset' not working
    Try: INFO-MENU-MUTE-ON with the remote control .
    • UKsparks
      • Nov 2015
      • 5
      • England
      Thanks Cliff.
      Worked first time.
      • cliff_hootarski
        • Jul 2006
        • 411
        You're welcome.
        • DynaxSC
          ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
          by DynaxSC
          I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
          Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
          Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
          The behaviour is also really very strange, i.e.:
          • The disk shows always up in BIOS - so it is recognized, so far so good
          • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
          02-23-2025, 01:33 PM
        • lafilipczyk
          lc 80le632u - Lamp error - TV working after counter reset via buttons
          by lafilipczyk
          Hello everyone, I just got my hands on a Sharp lc 80le632u TV that initially had the 1 short, 1 long blink sequence. That indicates a lamp error, however if I follow the isntructions to reset the error counter, the TV starts correctly: no missing LEDs everything lods just fine.
          I went through the process to get to the diagnostic screen, and got this ( attached).
          Since all LEDs are working correctly, and the TV seems to load fine after reset, that tells me that the power board and the LED strips are working correctly. Could this be a main board issue?
          Any...
          07-29-2024, 11:00 AM
        • sahraoui1
          reset toner samsung m2022w
          by sahraoui1
          hello friends,
          i'm searching for the dump Samsung sl-m2022w in order to fix problem and reset .
          Machine Serial Number : ZF47B8GF7D00JHM
          System Firmware Version : V3.00.01.10 JUN-19-2014 (M2022W)
          Serial No. : CRUM-14121900958
          thanks bro
          09-20-2025, 12:52 PM
        • nader_guesmi
          Samsung UE65TU7172 – BN41-02751C – CI+ ECP Keys Missing / Digi Card Not Working
          by nader_guesmi
          Hey everyone,
          I’m working on a Samsung UE65TU7172 with mainboard BN41-02751C. The TV powers on normally, I’ve applied the latest software update, and all measured voltages are correct.
          Problem: The CI+ module doesn’t read the Digi card.
          I accessed the service menu (using Mute + 2 + 4 + 7 + Exit) and ran the CI+ test. The results show:
          • CI+ production keys: Success
          • ECP keys: Not installed
          So the TV doesn’t even attempt to communicate with the CAM/card.
          I’ve tried multiple Digi cards (both old and new), and they work fine on another...
          09-09-2025, 03:04 PM
        • notallbad
          Samsung UE55JU6000K stuck at 'Setup Conplete'
          by notallbad
          Reset the tv as internet connection not working, connected to router but no internet.
          Did a factory reset and completed the initial setup process but now just freezes on 'Setup Complete' page.
          Going into service menu it says 'Failure' at the top of the page and unable to access the 'control' screen.
          Its already on T-HKM6DEUC1570.0 fw.
          Are the SVC reset options likely to help here?
          options are
          apps reset
          svc reset
          spi flash reset
          data sync reset
          Any help appreciated.
          08-26-2023, 10:44 AM
