Samsung LCD LN32C450 Power Problem
  • tech2014
    • Aug 2014
    • 807
    I got a tv that when powered up, it stays on for a few seconds and then the power LED goes off and stays off. I found that when I removed the connector going from the power supply to the inverter board, the power would stay on and the power LED would stay a solid red, but tv would still not power up. I assumed it was a bad inverter board, so I replaced it. I put the new board in and same problem. The power supply is BN44-00338B.
    I was able to test the power supply. With the p/s out side of the tv, I was able to get voltages WITHOUT putting 5v on the PS_ON pin. I get the following voltages
    5.3v=ok
    5v=ok
    13V=16.5V
    24V=31V
    I googled this power supply and apparently there are issues with a SIC cap CM808 and ICM801. I removed the cap CM808, which is 18nf. I measured it out of circuit and it measures 2nf.
    Would this cap having too low capacitance cause the voltages to be higher then normal or am I missing something here. thanks
    Below is a pic of the power supply, back of the TV and the power supply schematic. Any help would be greatly appreciated.
    Re: Samsung LCD LN32C450 Power Problem
    First, you need to check the battery of your meter, your readings are way high so more likely the battery is low.
    Low capacitance will cause the 12V/24V DC to be low.
    • paulstef
      • Dec 2013
      • 724
      2nF instead of 18nF is definitely not good in a resonant power supply. It needs to be replaced.
      If you test the PSU disconnected from the rest the voltages are probably higher though because they are not loaded.
      • tech2014
        • Aug 2014
        • 807
        BUDM, I did replace battery a couple weeks ago so its not the battery.
        • tech2014
          • Aug 2014
          • 807
          I get PFC voltage of about 390V going into CM808, which measures 2nf out of circuit, so I am going to order a new part. Should I replace ICM801 as well?
            That cap is the coupling cap to drive the power transformer, when the capacitance is low the output Voltage will be really low with only 2nF, so yes replace cap first since it is the commonly failed cap.
            • tech2014
              • Aug 2014
              • 807
              thanks guys
              • johns1mj
                • May 2015
                • 242
                I have the same problem and found a repair kit on ebay for $15. I am going to try it. While in I have all my powers and grounds according to the chart posted on the power board. Unhooking the t-con and led driver did not produce any changes.
                • johns1mj
                  • May 2015
                  • 242
                  I now have back lighting if I unhook the input board but no joy on the start up chine. No back lights if I leave the input board hooked up. I also get no response on the touch buttons.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Mainboard is faulty then.
                      by sam_sam_sam
                      03-31-2024, 02:12 PM
                      by sam_sam_sam
                      07-01-2024, 06:34 AM
                    • cheeky2
                      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                      by cheeky2
                      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                      06-15-2025, 05:12 AM
                    • JimBanville
                      Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                      by JimBanville
                      The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                      Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                      I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                      I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                      09-13-2023, 07:21 AM
