Vertical lines, kdl-40lx900, i susect tcon
  • ReeceyBurger123
    replied
    Re: Vertical lines, kdl-40lx900, i susect tcon
    Is there anyway to bring the menu up, if so is it distorted ?
  • Dogcatdog
    replied
    mainboard huh? so how to test it? is there a way of testing that? there are not much components on the mainboard,actualy less then on the tcon i guess it cant be that hard to find. thank you in advance.
    Originally posted by ReeceyBurger123
    That isnt an As15 or gamma Ic fault. I would say mainboard tbh.
  • ReeceyBurger123
    replied
  • Dogcatdog
    replied
    here a picture of the fault,
    and another one of the backside of the tcon, i found some test points and in 2 of those there is a voltage jump from 2.xxV to 3.xxV not sure if that is normal, but i think its not, both of those test points lead on the backside of the board connected to a 8 pin chip with markings "4256bwp ST k008h" i wonder if that is the culprit, i know that tcons are in generally fixable as long as one can find out what the problem is, like for example some sony have a as15-f chip that needs replacing and that fixes it, this tcon does not have that chip on board so i wonder what the problem is, it could also be something else.
    thank you very much in advance
    Pictures of the fault please.
  • mistertv
    replied
    have you checked the flat heat-sealed under the metal frame of the display?
  • ReeceyBurger123
    replied
  • Dogcatdog
    started a topic Vertical lines, kdl-40lx900, i susect tcon
    i suspect it is the t-con since it has vertical purple and white lines and a bit of grain.sometimes it gets worse sometimes a bit better, but the lines are always there, i might be something else, im not sure, i cleaned all the contacts with alcohol of the flex cable and the (LVDS cable on both sides) that is connected to the tcon to see if that fixes it, it did not change, it was still the same.
    the kdl-40lx900 has the same tcon as the kdl-52lx900
    no blinking no error code it just works, but the picture is as said with vertical liknes over the whole display in even spaces, sometimes a bit of green gets to the vertical purple/white lines
    the tcon is CPWBX4351TPZF, oddly enough its a Sharp RUNTK4351TPZF
    i would like to identify what is defect and repair the Tcon board since replacing it is not an option for me.
  • Stanley1843
    by Stanley1843
    06-29-2024, 11:54 AM
  • Daren87
    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
    by Daren87
    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
    08-13-2023, 03:25 PM
  • Falki
    Colorful LCD Vertical Lines on Samsung ue55es8090
    by Falki
    Hello there, ive recently found an older 55inch Samsung SmartTV.
    A similar issue has been posted as well but also with no actual response ...
    08-12-2025, 04:19 AM
  • gpo23
    Sony KDL-40V3000 - Vertical lines
    by gpo23
    i order a t-con because i had bad colors on my SONY KDL-40V3000 :
    With the new t-con the color are good but there are vertical lines on all the screen :
    I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
    Is there a way to fix the vertical lines on the new t-con ?
    Thank you for your help
    gpo23...
    10-04-2023, 09:11 AM
  • x_orange90_x
    TCL 50S535 bad tcon or panel issue?
    by x_orange90_x
    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
    03-29-2025, 11:02 PM
