Samsung le37b530 flickering backlight
  • apeter1
    • Nov 2015
    • 21
    • Hungary
    Re: Samsung le37b530 flickering backlight
    Is only the 55.37T05.C09 good for my tv or all T370HW02 37T04-C0G board with similar numbers?
    • apeter1
      • Nov 2015
      • 21
      • Hungary
      The store has only EC5575-HF so I could replace the AS15-HF on tcon to EC5575-HF. The bright colours flickering is disappeared but the colours are pale. Could it caused by the different chip type?
      Thanks,
      Péter
      • apeter1
        • Nov 2015
        • 21
        • Hungary
        Could be damaged the chip during soldering?
        Thanks,
        Péter
        • apeter1
          • Nov 2015
          • 21
          • Hungary
          The black and blond is grey:
          https://www.youtube.com/watch?v=9cAtkch5kr0
          https://www.youtube.com/watch?v=9LpeqmUn1j8
          • orinoco8
            • Jan 2016
            • 26
            T-CON should be good (if image remains good through the flickering of backlight). Try to check the DIM and INV signals coming from mainboard to power supply.
            • apeter1
              • Nov 2015
              • 21
              • Hungary
              #26
              There was not flickering of backlight. The title of topic is my fault. There was problem with bright colours: https://www.badcaps.net/forum/showthread.php?t=50132
              What should I check between mainboard and power supply? How can I check it?
              Thanks,
              Péter
              • orinoco8
                • Jan 2016
                • 26
                No sure (I am not experienced enough with bright color flickering issues). You can still check the voltage of INV and DIM signals (from main board). See whether they change as the flickering intensifies.
                • Cyberknight13
                  • Oct 2016
                  • 9
                  • Russia
                  #28
                  I am posting this here as I believe the issue on my TV is also a backlight problem. I am going to follow the steps in this thread, as well as similar ones here, but I wanted to post my specific problem in any case.
                  I have a Samsung LE37B530, specifically LE37B530P7WXRU (Russian model). The issue I am having is that when I power on the TV I usually get a black screen with sound. If I shine a flashlight on the screen I can see very faint images. Sometimes the TV will work normally and occasionally I get screen flicker intermittently.
                  The issue seems to have worsened over time as it started with just flickering when I was using the TV with my laptop via HDMI. Now it is almost always black screen with sound. I reset the TV to default settings via remote (exit button for 12 seconds then chose reset when it appeared on TV) but it did not seem to have any effect.
                  I am going to disassemble the TV now for troubleshooting and will advise.
                  • Cyberknight13
                    • Oct 2016
                    • 9
                    • Russia
                    #29
                    First video is with main board and power board connected and TV powered on. I get flickering, solid and rapid flickering backlights.
                    https://youtu.be/BLDHSPNx36g
                    Second video is with boards disconnected and TV powered on. I get solid lights on.
                    https://youtu.be/04RwkljgY5I
                    Third video is with boards disconnected and TV powered on. I get flickering lights.
                    https://youtu.be/uptMy9HI_HA
                    • Cyberknight13
                      • Oct 2016
                      • 9
                      • Russia
                      #30
                      Any advice based on the videos above? I'm a noob and not sure where to go next.
                        I would check the DCV between the two legs of the main filter cap to see what you have, it should be around 380~400VDC.
                        • Cyberknight13
                          • Oct 2016
                          • 9
                          • Russia
                          #32
                          Sir, thank you for the response and advice. I assume you mean the 2 big blue capacitors in the attached photos. I set the multimeter to 1000 DCV and get a 1 reading on both capacitors.
                            1VDC? Are you sure your meter is OK? Where EXACTLY did you put the meter probes? TV plugged in and turned on?
                            • Cyberknight13
                              • Oct 2016
                              • 9
                              • Russia
                              #34
                              The multimeter works as far as I can tell. I tested it on some batteries and other components. I placed the probes on the exposed legs of the capacitors with the TV turned on and set the multimeter to 1000 DCV as the next closest option is 200 DCV. I did a quick video of it so you can see what I did. I hope I did everything correct and don't appear too foolish.
                              https://youtu.be/L6VbS2XmulI
                                The meter is telling you it thinks it is OVER RANGE even on 1000 VDC scale which is impossible. The meter is bad.
                                • Cyberknight13
                                  • Oct 2016
                                  • 9
                                  • Russia
                                  #36
                                  Roger that. I'll go get a new one on the 1st.
                                  I'm assuming the capacitors are likely the problem with the TV due to the intermittent problem. I had a similar issue on a PC LCD once and replaced the capacitors. It still works fine 6 years later. The capacitors also aren't bulging but they aren't as recessed as I think they should be. I'll attach a pic but it is likely hard to tell. Obviously I'll do more proper troubleshooting once I replace my meter.
                                  Thank you for you assistance and advice!
                                    I am not suspecting the main filter caps problem but the PFC Boosted Voltage problem that is on the edge of shutting down/restart.
                                    • Cyberknight13
                                      • Oct 2016
                                      • 9
                                      • Russia
                                      #38
                                      Any idea where that would be and what it would look like on this TV? I understand the concept of what it is but otherwise lost on that one. Here is the service manual for this series of TV.
                                      https://drive.google.com/open?id=0B4...FROQ19IeXV1cm8
                                        That is why I have you measured the Voltage at the two legs of the main filter caps, but you need to get your meter to read the dcv correctly first.
                                        • Cyberknight13
                                          • Oct 2016
                                          • 9
                                          • Russia
                                          #40
                                          Understood, thank you sir. I'll likely get it on the 1st and pick your brain some more then.
                                          • sliceypete
                                            Samsung LE52B620 - Flickering backlight
                                            by sliceypete
                                            Hello All,
                                            My Samsung LE52B620 started to have backlight flickering about a year ago, it would only last for about 10 mins and then the backlight would stay on.
                                            about a month ago the backlight flickering is constant and does not stop.
                                            I think it's a problem with the power supply board (BN44-00267b) or maybe the backlight is dying?
                                            I checked and all the caps look to be fine.
                                            I do not believe it is a problem with the mainboard, since I unplugged it from the power supply and the backlight came out but still flickers.
                                            08-04-2021, 05:11 AM
                                            09-07-2024, 05:50 AM
                                          • sansanpartida
                                            Samsung QE82Q70RAT no backlight
                                            by sansanpartida
                                            Hi everyone!
                                            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                            My issue: No backlight.
                                            Model: QE82Q70RAT
                                            Type No: QE82Q70RAT
                                            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                            So hopefully, I can fix this cheaper.
                                            05-22-2024, 06:56 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
