Westinghouse VR3215
  • dmesser100
    • Oct 2011
    • 53
    Westinghouse VR3215
    Hi all, this one has kinda stumped me. Red light is there but power button does nothing, no clicks or picture nada. caps and diodes seem good, tested diodes, caps did a visual. only get 5vdc on the vstb pin. would this be a eprom on the main board problem?
  • dmesser100
    • Oct 2011
    • 53
    Re: Westinghouse VR3215
    mosfets checked out fine too. think im goin to order the eprom and give that a shot
    • dmesser100
      • Oct 2011
      • 53
      ok, eprom replacement did nothing
      • dmesser100
        • Oct 2011
        • 53
        I only get 5volts in 5vbs. anybody got some advice? don't mind buying a board to fix, just need to know which one main or power.
        • caspian
          What Zener Diodes on a Linear Power Supply
          by caspian
          Dear members,
          I have a linear variable power supply with unknown brand name that I used for voltage injection.
          Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
          In addition, I discovered that its zener diodes are defective.
          I can replace the burned transistors.
          But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
          Therefore, I cannot replace the zener diodes.
          I do not want to test the zener diodes in a test circuit to discover their model or value.
          no schematics are available...
          05-26-2025, 12:38 PM
        • Nikolai Danylchyk
          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
          by Nikolai Danylchyk
          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
          Thanks in advance!...
          05-08-2025, 06:18 AM
        • Fontana
          BN44-00505A dead. Need to know voltages on output diodes (Samsung T22B300EW)
          by Fontana
          1. g´day! I have a samsung 22" tv monitor to fix. power supply model bn44-00505A. some stuff blown up on the primary, according to research something typical on this model. secondary seems ok. writings on the board say in outputs a5v (standby), b5v (switched) both on the lower 3 diodes on the picture, vamp and b13v (12.8v, both are the linked at the connector that goes to the main board) my question is, are both the upper diodes for 13v? I believe so but wanted to make sure before injecting voltage there to test. I injected 5v on the lower side and standby circuit is working fine
          2. if
          12-18-2023, 05:45 AM
        • DjKrish
          Zener diodes component equivalents
          by DjKrish
          Hey guys, i have a sony home theater power supply thats a few smd zener diodes blown but its so hard to get them. any recommendation for me to use normal zener diodes?
          1. UDZSTE-1710B (9.99V 5mA) (SC-90, SOD-323F)
          2. UDZSTE-1724B (24V 200mW) (SC-90, SOD-323F)
          3. UDZSTE-175.1B (5.1 V 200 mW) (SC-90, SOD-323F)
          These are the diodes. If i use normal zener diodes, it will work right? Question is, can i get these values on normal zener diodes?
          08-15-2021, 11:06 PM
        • madyoyo
          Samsung QE55Q65B with shorted D001 diodes on panel board: Worth saving or not
          by madyoyo
          Hi
          I have a Samsung QE55Q65B with a seemingly common problem: it turn off and back on after a few seconds, (sometimes more, and in rare instances works for hours). D001 on the left side of the panel is very hot. I may be able to remove it with a very fine iron, but i don't have the equipment to re-solder such small parts.
          Is there a risk to run the tv without this diodes diodes? And is it worth to pay someone else to replace it. I read many people who ended up with bad lines after trying to remove/replace them, , or the panel failing in another way, so i want to weight...
          12-01-2023, 09:28 AM
