Vizio E470VL color bar in side of the screen
  • Jramos13
    • Oct 2015
    • 7
    • Puerto Rico
    Hi guys! Im trying to troubleshoot my vizio E470VL, i had the main board go bad once do to a power surge and i replaced with a used one i got from ebay, that was about 2 years ago, now i have this cyan/bluish/greenish bar on the side of the screen, it was going away after 1-2hours but now its not going away anymore, its more noticeable with some colors and less noticeable when something of a lighter color shows ups, i dunno if this might be the power supply board or the main board or the lcd itself, any help is greatly appreciated!
  • Jramos13
    • Oct 2015
    • 7
    • Puerto Rico
    Re: Vizio E470VL color bar in side of the screen
    Sorry for the repkys with picstures, it does not let me upload all at once
    • Jramos13
      • Oct 2015
      • 7
      • Puerto Rico
      Sorry for the replies with pictures, it does not let me upload all at once
      • freakaftr8
        • Oct 2012
        • 3743
        I believe that model has the main board and t-con board built into 1 unit. I'd say replace it. But before I do that try disconnecting and reconnecting all the cables to make sure you don't have a bad connection. This does not look like the panel has failed
        • CapLeaker
          Leaking Member
          • 8222
          tab bonds
          • Jramos13
            • Oct 2015
            • 7
            • Puerto Rico
            Thanks for the replies! Yes i just tried disconnecting a reconnecting everything and nothing, so the lcd panel should be good and it should be the main board then? Is that something that canbe fix or it would need to be replaced?
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • ravi_1617
              HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
              by ravi_1617
              Hello to all ,
              I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
              Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
              on external VGA port image is perfect /normal , Attached image...
              07-25-2025, 12:07 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • frannyjunk
              Vizio M60-C3 left side of screen + a couple other areas dim
              by frannyjunk
              My Vizio M60-C3 was dead. No power, no lights. Just nothing. So I took the back cover off and noticed 4 bulging caps on the power supply board, so I replaced them (green low esr capacitors in the picture). The tv now works! But there are some areas that look dim (see picture). In particular, the left side has a dim band. I know that the led strips run horizontal, yet this band is vertical. Could it be that the led driver board is bad? Could the blown caps have taken out the led driver board? Or is this just a coincidence that every left side led on each strip just went out?...
              11-10-2021, 08:09 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
