Samsung LN32D403E4DXZA Screen refresh/delay question
  • jstiene
    • Feb 2013
    • 148
    Hello.
    I have a Samsung LN32D403E4D that has a strange issue. It seems that every 5 seconds while watching a show, the screen will freeze for a moment, and then continue on...almost like a freeze frame..barely noticeable but it exists. Has anyone else encountered this time of problem?
    any advice is appreciated...
  • jstiene
    • Feb 2013
    • 148
    Re: Samsung LN32D403E4DXZA Screen refresh/delay question
    Hello. wondering if anyone has encountered this problem. It now has gotten worse where the video freezes for about 30 seconds, and then continues for about 5 seconds and then freezes again..this cycle keeps repeating...
    any suggestions what causes this video freeze effect?
    Thanks!
    • freakaftr8
      • Oct 2012
      • 3743
      Is the screen dim and lagging like slow refresh?
      • sordids999
        • May 2013
        • 2149
        • uk
        Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
        • jstiene
          • Feb 2013
          • 148
          freakaft8,
          yes, the screen is dim and lagging like a slow refresh...that is the exact problem that I am having..
          • jstiene
            • Feb 2013
            • 148
            Hello...just following up to see if anyone else has encounter this slow lag/screen refresh issue...I was wondering if this is a common problem...any help would be appreciated..thanks!
            Joe
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • Chrissygizmo
              samsung galaxy ao2s very temperamental after screen replaced
              by Chrissygizmo
              Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
              Ive eventually managed to get it on and working but it's very temperamental...
              The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
              05-26-2024, 12:05 AM
            • Kiberge
              Samsung LH82QENELGC/EN Help needed - Static line on screen
              by Kiberge
              HI guys!
              I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
              I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
              the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
              This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
              04-22-2024, 11:28 AM
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • arbitarytwist
              Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
              by arbitarytwist
              Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
              Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
              03-01-2025, 01:16 PM
