Proscan 55lc55s240v69
  • gdawg
    • Sep 2012
    • 170
    Thanks everybody for this great forum!! I have a Proscan 55lc55s240v69 that did not power up when I first got. I have read all the posts on this tv and of course the first thing was to remove the back and visually inspect. The p.s. had 3 1000uf caps with the tops bulged pretty bad. They checked at 400-500 uf. I just replaced the 3 to check and see if it would power up and it did. I noticed a high pitch squeal noise at t-801 transformer when it was on. I went ahead and replaced all the electrolytic caps thinking it would take care of it. The tv powers on fine, but the noise is still there. I can feel a vibration when I put my finger on the infamous C857 cap. I did not replace this as it looked good and checked out capacitance. I don't have an ESR meter. I know this high pitch noise is usually from a leaking cap or a diode. The only diode I see that's attached to that c857 cap is on the back of the board vd804. I did test all diodes on the front and removed one leg to check. With the c857 removed, I diode checked the vd804 and showed .537 volts one way and .213 volts when leads reversed. I didn't want to remove to check cause of the size. So I guess my question is what would cause this noise and any way to verify or is it replace one part at a time to see what corrects this. Oh, by the way, The c857 cap is the 22nf 2kv style. Any help would be appreciated. I know some noise is normal, but this is a high pitch squeal noise. you cant hear it from the front, but the back is loud and fear it will take out something else. I hope I did the pictures right.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Proscan 55lc55s240v69
    Possibly primary caps are causing the issue due to being dry and going up in esr.
    • gdawg
      • Sep 2012
      • 170
      I thought about that, but because the noise is definitely coming from the t801 transformer, I thought it would be something in that circuit. Especially when you can feel the c857 cap vibrate. Thanks for the reply and the info.
      • gdawg
        • Sep 2012
        • 170
        Swapped the main filter caps with known good ones and no change. I forgot to mention the noise sounds like a frequency noise and does not change with brightness of picture. Also, the panel has to be lit for the noise to appear. The power supply has to have video to make the noise. I disconnected the t-con and of course no picture, just audio and no noise. I am not that good at theory of how everything is laid out. I sure hope someone can lead me in the right direction for things to check. I did replace the small ceramic cap next the c857. The diode I checked earlier all seems to be same readings as other zener diodes on the back of the board.
        • tony359
          by tony359
          11-28-2023, 05:18 AM
        • MegaZAC
          Onkyo TX-SR805 noise in one channel
          by MegaZAC
          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
          There's some logic behind it. As soon as I select an input I get only left...
          04-23-2025, 10:09 PM
        • courtcircuit
          Philips HTS8000 home cinema noise problem
          by courtcircuit
          Hello
          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
          Removed each of tyhe boards
          02-08-2025, 08:22 AM
        • roadrash
          Old PC PSU making noise etc
          by roadrash
          A vintage 1980's PC power supply has started making a hissing and whining/squealing noise and the PC is now giving random errors like memory and video etc. Ive tried the PSU with just the Motherboard plugged in and its quiet but soon as I increase the load adding controller interface cards and drives etc, the noise starts. I think there is something about to fail but cannot see anything like a bulging cap or anything. Does anyone know whats the most likely suspect component? Here is a link to a video i took....
          Yesterday, 09:02 AM
        • karatzdi
          Denon AVR 1908, High pitch noise on Surround back Left channel after long overhaul
          by karatzdi
          I know some might say... just buy another one. Sell it as parts..!
          So had this AMP for quite some time. Recently I saw light smoke coming out of the AMP. Had my fire extinguisher close by. Just kidding. Turned immediately all devices off from mains.
          Let things cool a bit, and opened up the amp device. I clearly saw on the main board which hosts the 5X amp (5.1), 3 10 ohms 1W resistors had their leads looking black, while the rest of the remaining 2 x 10 ohms were brownish as being installed from factory.
          Spent some time downloading the Service...
          06-11-2024, 08:38 AM
