No power unless plugged in for 20 mins - Philips LC260WX2
  • jamesf2
    • Jul 2015
    • 22
    Hi all
    Bit of an unusual one here. I have a Philips LC260WX2 which only shows signs of power after it has been plugged in for 20 minutes. Before that, it's completely dead, not even a standby LED. Once it kicks in, it works perfectly until power to it gets switched off and it is left to cool down. It will work normally for days as long as it is left in standby when not in use.
    I've dealt with plenty of problems where TVs won't power on from standby, usually caused by bad caps, but this is the first time I've had a problem like this where it struggles to even take enough power for standby.
    Does anyone have any suggestions? Could we be just talking a straightforward cap replacement, or maybe something more serious? I just wanted to check before I waste too much time working on the wrong components.
    Thanks in advance.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: No power unless plugged in for 20 mins - Philips LC260WX2
    It could still be bad capacitors that haven't failed by blowing up. Do you have a hair dryer handy ?
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      Freeze spray can help narrow it down too. When you find the area of the board that responds to the heat then start hitting individual components with freeze spray there until it malfunctions again. You can use canned air upside down for a freeze spray.
        • 31183
        sounds like a standard startup cap problem.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          I assume by startup cap you mean primary cap. Yes, I'd start in that area too and move down the power chain.
            • 31183
            small usually 10-47uf cap powering the controller i.c.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Turn the tv on from cold and start heating the Psu to see if doing that helps it turn on faster. Also what cap brands are used in this one ?
              • alro7779
                Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                by alro7779
                Hello, guys!
                The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                09-14-2025, 12:25 AM
              • Bad_IC
                Philips TV 37pfl5604h/12 no standby voltage
                by Bad_IC
                I have a problem with this TV, the standby voltage is not present. I have checked the components around the IC fsq510's area and they seem to work, also replaced this IC but the problem persists.
                These are the voltages in some pins of IC fsq510:
                Vcc=18v
                D=320v
                Vstr=154v
                Unfortunately, I couldn't find the schematic
                What else could I check?
                Is it possible to provide standby voltage from an external source to allow the TV to turn on?
                Thank you​...
                11-08-2024, 01:07 PM
              • Raulnn
                Philips 43pft4112/12 blinking standby
                by Raulnn
                good evening. I have this basic tv, with an all-in-one board. This tv has a common fault in the primary power area. the tv did not turn on. I bought a repair kit. I have installed all the parts of the kit, but now the tv turns on the standby light intermittently but does not start. the flashing is very fast. What can be? Does anyone know the model? Thank you
                01-08-2023, 04:13 PM
              • Shinju
                Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                by Shinju
                Hey All!
                Long time forum member here with a problematic laptop issue!
                I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                The laptop would not power on with the new battery installed without the power supply being plugged in.
                When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                10-20-2021, 04:58 PM
              • fixitjunkie
                Samsung UN48H5500AF - no standby, no video, no sound, backlights on when plugged in
                by fixitjunkie
                Hello All,
                Picked this up at a recycle center with hopes of a simple fix.
                When plugged in, the backlights come on, two blue LEDs on the T-con board illuminate then one goes out. Cycling the on-off switch has no effect.
                On the power supply board there are four test points labeled +, sine wave, sine wave and -. There is 120VAC across the sine waves and 113VDC across
                + and -. All the caps look good.
                I'm not sure where to check for the standby voltage output?
                Shop Jimmy's has plenty of PS boards, Main boards and T-con boards....
                11-12-2021, 07:31 PM
