Samsung PN60E550D1F no audio no image only red LED
  • jose6326
    • May 2013
    • 707
    Re: Samsung PN60E550D1F no audio no image only red LED
    i did contact shopjimmy but they do not have their tech support line setup yet
    so i sent an email to their "general questions" dept
    hopefully they can provide some help as well
    • Chetty1977
      • Oct 2015
      • 5
      My Y main dont have a spot for the C 5162. My tv was made in 2012. I see in pics here where it should be. But no spot on my board for it. Any help would be great
      • jose6326
        • May 2013
        • 707
        Can someone explain why vsc goes to -65.5v when I reconnected the buffer boards?
        I also had the cable disconnected from ysus to logic board
        With buffer boards disconnected vsc is -12.65v
        • jose6326
          • May 2013
          • 707
          shopjimmy sent an email stating to order parts from digikey and they had no tech support at the moment
          • jose6326
            • May 2013
            • 707
            post a picture of your board
            • Chetty1977
              • Oct 2015
              • 5
              I dont know how to post pictures. I will have to look into that. But it looks like all the y boards posted on here.
              • Chetty1977
                • Oct 2015
                • 5
                Ok here's my y board
                • jose6326
                  • May 2013
                  • 707
                  thats odd your board doesnt have a location for the blue cap
                  maybe its a different revision
                  have you tried spraying freeze spray on the ic chip at U5014?
                  or putting the board in the freezer for a couple of minutes and reconnecting it
                  i read in other posts that it will help to isolate the problem to the ysus
                  • Chetty1977
                    • Oct 2015
                    • 5
                    I replaced that chip. I left a message in another post I seen you in. It explains what my TV is doing. You just posted in it like 3 days ago. Drusell started it. But I get red/pink flashing then the TV will shut off. But that only happens when the background on my TV is white. If its a dark color the TV will stay on most of the time.
                    • jose6326
                      • May 2013
                      • 707
                      well im lost just as you are
                      i am going to have to remove some of the mosfets i didnt replace and check those out
                      maybe i can send you my repaired board and you can tell me if it works in your tv
                      • HobieSimons
                        • Dec 2015
                        I have a Pn60e550d1fxza that is exhibiting similar problems but not all the time.
                        If I disconnect power for awhile, then reconnect, I am able to get picture for various amounts of time, but the amount of time seems to get shorter.
                        My nameplate V numbers are:
                        Vs = 211
                        Va = 57
                        Vsc = -198
                        Ve = 98
                        When the TV is working correctly, I get the same values except Vs is slightly higher at 212.
                        When the picture is lost (still have sound), I have the green LED flashing 5 sec on and 2 sec off.
                        The V values are:
                        Vs = 10v
                        Va = 0v
                        Vsc = -0v
                        Ve = 11v
                        This values are nearly exactly as indicated in the original post.
                        I have read the entire thread. I haven't pulled cables off to check voltages in various conditions, but the initial feedback was to swap out the Y Sus.
                        The owner in this thread attempted a repair but still had the problem.
                        I am inclined to just go ahead and swap out the Y trio and maybe even the X.
                        I am wondering what the outcome of this problem was since it seems exactly like my case.
                        • HobieSimons
                          • Dec 2015
                          I should also add that while I did have picture I was able to get into factory mode and took a picture of the SVC menu. The picture is attached. Any insights to what the errors may mean on several fields?
                          • CoppellTVRepair
                            • 39
                            #73
                            I read that thread while researching repair for the YSUS.
                            We are repair service center and you can quote this if you want: there are companies out there - ShipJimmy being among them - that offer repair kits that are highly unlikely to be based on first hand experience repairing boards.
                            There are boards that we've repaired hundreds of and I NEVER, I mean NEVER have seen particular parts fail that are being offered as a repair kit.
                            Which is not to say that *everything* they sell is bad.
                            What it means is this: before ordering a repair kit from a company try and see if they are ready to take in the board for repair for you.
                            If not then that's one big red flag in my eyes.
                            There are vendors on eBay that sell HUNDREDS of different repair kits and not a SINGLE repair service.
                            • Nick's Tvs
                              • Jan 2014
                              • 621
                              Coppell TV repair is correct, lots and lots of "repair kits" that don't repair any common fault.
                              ZEMTRONIX sells lots of repair kits and every single one I have gotten from them has never repaired anything. They don't offer a repair service for any of the repair kits they sell. Big red flag indeed.
                              I spoke with a guy that actually performs repairs on vizio parts and says ZEMTRONIX is one of the bigger EBAY scams for tv repair. They sell you stuff that never fixes anything.
                              Back in the day, I had purchased a so called repair kit for a 42" Vizio main board from ZEMTRONIX, and nothing changed. I then got one from coppell and boom back in business. Which btw thanks Coppell, you definitely have helped out on many repairs where I was just clueless
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                #75
                                I have the same Tv in atm the control board has failed giving intermittent Vs on signal. Seems like some Bga solder on the Ic on the control board has broken.
                                • angelos
                                  Samsung LED TV Model UA49N5000AR (Flipped image)
                                  by angelos
                                  Hi Guys, this is the second time that I see this exact same issue on a Samsung. The tvs image is upside down and the set refuses to enter service mode (info, menu, mute, power).
                                  To me it seems that the firmware has become corrupt and this prevents service mode access. Has anybody on this forum ever fixed this without changing the motherboard?
                                  I tried to load firmware from Samsung website but as usual this is shit. The software version available online is older than what is loaded on the tv.
                                  08-26-2023, 09:18 AM
                                • fuxxy
                                  Samsung LN46A850 - Displays image that degrades, then reboots
                                  by fuxxy
                                  Samsung LN46A850. Purchased new like 150 years ago.
                                  This unit recently started doing this.
                                  Power the TV on, it powers up and displays picture. Picture will display fine for about 5-10 mins, then the image degrades with static-like horizontal lines until the set turns off, then the set will turn back on and the process repeats. When the horizontal static lines appear, they push and stretch the remaining image below the static off of the viewable portion of the screen.
                                  While this feels like potential bad caps, I don't have a clue where to focus my efforts....
                                  08-02-2022, 08:18 PM
                                • maateusjo
                                  Samsung 225mw displays image for 2sec and go very dark
                                  by maateusjo
                                  I have a TV/Monitor Samsung SyncMaster 225MW 55,9 cm (22") 1680 x 1050 HD that shows image when turned ON but after 2 seconds the image gets very very dark.
                                  If you look at it in a certain angle with you will see that the picture is still there. This TV/Monitor has like 10+ years old so it can be many problems due the age, battery supply or due to Cap problems.
                                  Someone have any sugestion or help?
                                  Cheers,
                                  maateusjo.
                                  07-15-2022, 07:42 AM
                                • rattlesnake
                                  Samsung SyncMaster 955DF dim image fix
                                  by rattlesnake
                                  This display looks a bit dim but the image is otherwise fine. I already set the contrast to 100 and the brightness to 50 (more than that is counterproductive, it becomes hazy).
                                  To enable extra tuning, I have to enable the "Highlight Zone" function and stretch it to full screen. That way it looks really bright/intense and really good! I wish I could set it permanently like this, but as soon as you change the display mode/resolution or you turn the monitor off, you lose the "Highlight zone" config and you have to manuallly activate it again. Also, the manual says...
                                  08-12-2023, 07:03 PM
                                • suiramix
                                  Samsung LH49QMRE no image, just restarts
                                  by suiramix
                                  Hi again,
                                  I need some help to troubleshoot this 49 inch Samsung 4K... so, the tv is power up when mains cable is plugged-in without using the remote or the power switch. The LED backlight is on but no image (blank screen). The red power indicator is flickering when the remote is used and power off the unit but after few seconds restart by itself. Inspected the power supply board (BN44-00953B) no components damaged and at CNM 801 connector measured the voltages without the mainboard connected:
                                  pin 1) NC, 2) ANA_DIM=2.81V, 3),5),7) and 9) A13V=12.77V, pin4) OD_ON/OFF=0V, 6) BLU_PMW=...
                                  06-16-2021, 08:20 PM
